PlastiDip grill peotection
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 12 of 12
2009-2014 Cadillac CTS-V Appearance Mods Discussion, PlastiDip grill peotection in Cadillac CTS-V Series Forum - 2009-2014; I was thinking of blacking out my grill (original I know) and I was curious to know how you guys ...
    2112rush2112 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Coupe
    Jun 2013
    29
    11
    I was thinking of blacking out my grill (original I know) and I was curious to know how you guys got behind the grill to protect the radiator. I've seen pics of people disassembling the whole front end and I'm really not interested in going through THAT much trouble. Any advice is appreciated.
    45LongColt's Avatar
    45LongColt is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Sedan
    Aug 2012
    39
    Re: PlastiDip grill peotection
    When you open up the hood you can remove the plastic shroud that covers the area leading down behind the grill. The space is large enough to fit plastic grocery bags between using a wooden dowl or yardstick. You can also push them in from the grill as well, just spread them around by using a large blade screw driver through the grill spaces. Make sure before you spray none of the bags are touching any portion of the grill. Take your time and move them to cover the radiators and other components. Allow plasti dip to cure good before pulling up the bags through the top opening where you removed the shroud. I used a straighten coat hanger with a small curve to the tip to hook the bags and pull them up and out.
    Took me longer to prep and remove the bags than it did to spray it. Good luck!
    45LongColt
    Jun 2013
    29
    11
    Thanks. I took the shroud that you mentioned last weekend but I wasn't too confident that I could get bags in the small opening......much less get them back out lol. I'll probably try again this weekend.
  5. #4
    spdmn75 is offline Cadillac Owners Member
    Aug 2012
    El Paso, TX
    39
    9
    where are you buying plastidip?
  6. #5
    Jun 2013
    29
    11
    I got it at Lowe's. I think it's about $6 a can
  7. #6
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    689
    Any pics guys? Thinking about tackling the grilles soon.
  8. #7
    MSOsr's Avatar
    MSOsr is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 Thunder Gray CTS-V coupe and Raven Black 2007 SRX
    May 2007
    Jacksonville, FL
    572
    Quote Originally Posted by spearfish25 View Post
    Here's mine done last year...still no problems.
    Mike
  9. #8
    May 2013
    Naples, FL
    689
    Quote Originally Posted by MSOsr
    Mike
    Sweet. That's exactly what I want. Did you prime it before or glossify after? Or just straight black plasti dip?
  10. #9
    MSOsr's Avatar
    May 2007
    Jacksonville, FL
    572
    Just straight Plasti-dip. No glossifier and no priming.
    Mike
  11. #10
    May 2013
    Naples, FL
    689
    Just did mine up the other day. Straight black dip, 5 coats. Came out awesome. I really couldn't be more pleased with it. Thanks.
  12. #11
    brentwoodCaddy is offline Cadillac Owners Member
    Automobile(s): 2012 CTS V
    Jul 2013
    Brentwood, TN
    23
    Finishing mine now. Pretty easy to work with, and it does look good.
  13. #12
    Xaqtly's Avatar
    Xaqtly is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 WD Vagon 6MT "Unobtainicorn"
    Jan 2012
    Las Vegas, NV
    1,184
    I fed newspapers down into the space right behind the grilles. It only took maybe an hour total prep time, really not bad.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
