Changed out the DRL's. Before and After Pictures - Page 3
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Like Tree4Likes
2009-2014 Cadillac CTS-V Appearance Mods Discussion, Changed out the DRL's. Before and After Pictures in Cadillac CTS-V Series Forum - 2009-2014; Great info here guys, I would like to change out my fogs as well. Went on Hoen's site and it ...
  1. #31
    pro397 is offline Cadillac Owners Member
    Automobile(s): 07 Escalade
    Jan 2009
    10
    Re: Changed out the DRL's. Before and After Pictures
    I would like to change out my fogs as well. Went on Hoen's site and it says they are backordered. Did you guys buy them off their site or elsewhere? Any info would be greatly appreciated.
    Also, where is the fuse located for the DRL's, I'm going to disconnect mine instead of trying to replace them.
    Thank again,
    Tony
    2011 Thunder Gray Sedan
  2. #32
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    643
    DRL fuses are in the box on the passenger side of the engine bay...up by the grille. You remove the cover and you'll see all the fuses. There is a fuse schematic so you can find the right two on the inside of the cover.
  3. #33
    Black'10CTS4 is offline Cadillac Owners Member
    Automobile(s): '10 CTS4 Prem 3.6DI, '08 CTS4 Prem 3.6DI, '00 STS
    Sep 2012
    34
    88
    Yes, I bought the foglights directly from the Hoen website.
  4. #34
    May 2013
    Naples, FL
    643
    Quote Originally Posted by spearfish25 View Post
    I've noticed my right LED sporadically stops working. Sometimes it's on, other times it's off when it should be on. The left side always works fine. Any ideas?
    For anyone interested, I've found that one DRL LED is off sometimes when it should be ON. However, toggling the turn signal on that side turns the LED ON after the signal stops. Must be a wiring gremlin when using the LEDs.
  5. #35
    Sep 2012
    34
    88
    Thats good to know spearfish, thanks!
  6. #36
    May 2013
    Naples, FL
    643
    Unfortunately it doesn't work every time
  7. #37
    Stevey is offline Cadillac Owners Member
    Automobile(s): 2011 Cadillac CTS Performance 3.6
    Jun 2013
    6
    Are the fog lights and DRL the same bulb?
  8. #38
    May 2013
    Naples, FL
    643
    Not at all.
  9. #39
    mpouls1's Avatar
    mpouls1 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 Black Raven 11.99 @ 118mph stock
    May 2009
    iatethebones
    518
    Quote Originally Posted by Stevey View Post
    your inbox is full
  10. #40
    May 2013
    Naples, FL
    643
    Quote Originally Posted by mpouls1 View Post
    your inbox is full
    fixed
  11. #41
    agreif is offline Cadillac Owners Member
    Automobile(s): 08 CTS DI AWD
    Jun 2009
    85
    so are others having the problem with the LED DRL's not coming back on sometimes? I know they go off with the signal and then are supposed to come back on after the signal turns off. Just wondering before I pull the trigger on these.
  12. #42
    Purple87SS is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Black Raven CTS-V, 1987 Turbo Buick WE4
    Dec 2011
    244
    Dont, no company has made a reliable DRL bulb for our Vs, that will last for more then a few months of a time. Not worth the hassle IMO.
  13. #43
    daign is offline Cadillac Owners Member
    Apr 2004
    25
    DRL LED bulbs on my Evo X required special error free Resistor ballasts to keep the voltage from fluctuating and killing the bulbs. Without the Error Free ballasts the LEDs would die.
  14. #44
    mpouls1's Avatar
    May 2009
    iatethebones
    518
    Before you pull the trigger, the front bumper needs to be pulled off. As he said there is no really good bulb brsnd that wont burn out. Every watt I have seen has went out. Exchange at your own risk. Or just consider pulling the fuse
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
