Question regarding spacer
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 15 of 15
2009-2014 Cadillac CTS-V Appearance Mods Discussion, Question regarding spacer in Cadillac CTS-V Series Forum - 2009-2014; ...
    Trionalaw is offline Cadillac Owners Fanatic
    Automobile(s): none
    Dec 2011
    61
    249
    Iím installing 275/35/19 and 305/30/19 on my stock wheels on my 2012 CTS V Coupe. I understand spacers are recommended. I note I can get 11 mm for the front and 15 mm for the back. Some suggest running 15 mm all the way around.
    I do not drag race the car. Rather, I take it to driving schools. Obviously, Iím looking for road course handling.
    Any suggestions would be greatly appreciated.
    Thanks so much,
    Jim
    Rule12b's Avatar
    Rule12b is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V Sedan
    Dec 2010
    Los Angeles
    544
    Re: Question regarding spacer
    Quote Originally Posted by Trionalaw View Post
    I’m installing 275/35/19 and 305/30/19 on my stock wheels on my 2012 CTS V Coupe. I understand spacers are recommended. I note I can get 11 mm for the front and 15 mm for the back. Some suggest running 15 mm all the way around.
    I do not drag race the car. Rather, I take it to driving schools. Obviously, I’m looking for road course handling.
    Thanks so much,
    Jim
    So, as I mentioned in another thread. I run the OEM wheels but not precisely OEM set up. I widened the fronts and moved them to the rear, now 19x11. The rear OEM's I moved to the front. I run a fairly wide spacer on the rear (either 12 or 15 mm I think) and a smaller one up front (no idea). There is no rubbing, period. I'm only selling the complete set up because the car is getting set up for track-only duty. The handling is much improved with the bigger rubber.
    Now, on stock OEM's, I was under the impression that you can run the sizes you mentioned without any issues, but again, I'm not an authority on that since I didn't try it. I have read I think a lot of posts with people running those sizes on OEM setups without issues.
    Automobile(s): none
    Dec 2011
    61
    249
    Thanks for your input. I ordered 15 mm spacers all the way around because I wanted to keep the same ratio between the front track and the rear track. Why? I don't know! Probably like what Emerson said in Self Reliance "A foolish consistency is the hobgoblin of little minds."
  5. #4
    the blur's Avatar
    the blur is online now Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Oct 2008
    NY
    782
    Do you need longer studs with the spacers ?
    do you loose the hubcentric effect with spacers ?
    will they clear without spacers ?
  6. #5
    Rule12b's Avatar
    Dec 2010
    Los Angeles
    544
    Quote Originally Posted by the blur View Post
    The spacers are hubcentric. Good question on studs I don't recall but can find out. I think they are stock but they may not be. No, my set up will definitely not clear without the spacers.
  7. #6
    the blur's Avatar
    Oct 2008
    NY
    782
    Quote Originally Posted by Rule12b View Post
    I just got my V, so I'm asking 10 zillion questions. I'm not looking for every tenth of a second, just looking for a solid track day setup. thanks
  8. #7
    Rule12b's Avatar
    Dec 2010
    Los Angeles
    544
    Well then you are in the right place to ask 10 zillion questions. I'm happy to help. Just sorry you are East Coast so you can't hit a Challenge event with us out here. Ask away, lots of good info here.
  9. #8
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    49,842
    If your spacers are small, stock studs would be fine. Beefier spacers should have longer studs...
  10. #9
    hlantin's Avatar
    hlantin is offline Cadillac Owners Fanatic
    Automobile(s): Silver MT CTS-V Sedan - Recaro/Graphite Wheels
    Jan 2005
    Hollywood, CA
    294
    I ran 11mm spacers on my sedan, but I had longer studs. Not sure how much spacer you can run without needing longer studs? If you're going to a road course, might be worthing looking into getting longer studs if you're planning to run spacers.
    I have 4 11mm spacers if any are looking for some...
  11. #10
    Betiwin is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Sep 2012
    35
    65
    If they are bolt in hubs centric spacers longer studs are not necessary. I run 15 MM all the way around. Your stock wheels have holes in the back to accommodate this.
  12. #11
    the blur's Avatar
    Oct 2008
    NY
    782
    A picture would probably help.
  13. #12
    Rule12b's Avatar
    Dec 2010
    Los Angeles
    544
    Well here is the OEM widened switch. . .
  14. #13
    Automobile(s): none
    Dec 2011
    61
    249
    Ordered the spacers from Motorsport Tech. Its owner assured me everything would work with the tires I have ordered. Spacers came in today. I will know Thursday when I take the car in to have the tires mounted.
    I will report back and take some pictures.
  15. #14
    Automobile(s): none
    Dec 2011
    61
    249
  16. #15
    Rule12b's Avatar
    Dec 2010
    Los Angeles
    544
    You will probably need longer studs.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
