Anyone run 305 MT DRs on 18 inch TSW Nurburgrings?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree2Likes
2009-2014 Cadillac CTS-V Appearance Mods Discussion, Anyone run 305 MT DRs on 18 inch TSW Nurburgrings? in Cadillac CTS-V Series Forum - 2009-2014; Currently I'm running DRs on Z06 replica wheels. They work fine but are heavy. The TSWs are about 7pds lighter ...
    Chrispy's Avatar
    Chrispy is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS Luxury
    Apr 2012
    Ontario, Canada
    552
    Currently I'm running DRs on Z06 replica wheels. They work fine but are heavy. The TSWs are about 7pds lighter per wheel.
    I have 4 TSWs with snow tires mounted. I might pick up another two wheels, mount the DRs on them and sell the replica Z06s.
    They are both 40mm offset and same width but I don't know the backspacing.
    Has anyone run these before or know if they'll fit?
    Thanks in advance,
    Chris
    Ste_V_e is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Nov 2011
    279
    Re: Anyone run 305 MT DRs on 18 inch TSW Nurburgrings?
    I'm also curious. How much did the replicas cost you? and are they heavier than stock wheels?
    Low_ET's Avatar
    Low_ET is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V, Thunder Gray, Auto
    Mar 2009
    East Central Florida
    220
    With the TSW's 40mm offset, the 305 tire would stick out over an inch more than the stock 285 size on the stock 56mm offset wheel.
    The 305 with a 40mm offset will clear on the inside just fine.
    Some forum members have successfully used a 305-wide tire on the stock 56mm offset rear wheel.
  5. #4
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    552
    The z06 spyder wheels are the same offset but I need to verify backpacking.
    The replica /DR combo is about 3pds heavier than the stock rears/ps2s.
    The TSW NURBURGRINGS combo will be about 4pds lighter than the factory setup
    Cheers
    Chris
  6. #5
    Low_ET's Avatar
    Mar 2009
    220
    TSW Nurburgring 18x9.5 with 275/40/18 Nitto NT05 ----- 51.0 lbs
    Stock Sedan Front 19x9.0 with stock 255 PS2 ------------ 51.5 lbs
    Stock Sedan Rear 19x9.5 with stock 285 PS2 ------------ 55.5 lbs
  7. #6
    KEV-V's Avatar
    KEV-V is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Dec 2007
    Canada
    127
    I am running the 18" TSW's with 40mm offest and MT 305/35/18 drag radials, no problems, no rubbing.
    Quote Originally Posted by Chris CTS V Wagon View Post
    Thanks in advance,
    Chris
  8. #7
    KEV-V's Avatar
    Dec 2007
    Canada
    127
    Attachment 99896
    Thanks in advance,
    Chris
  9. #8
    Nov 2011
    279
    Where can I pick up a rear set and how wide are they? I have a coupe and looking to run the 305/35/18 MT's with these.
  10. #9
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    552
    Awesome thanks! I might pick up two more and sell the repro Z06 spyder wheels.
  11. #10
    BMBSALES's Avatar
    BMBSALES is offline Cadillac Owners Enthusiast
    Automobile(s): 10 CTS-V, 13 ESCALADE, 06 C6, YAM R1
    Mar 2006
    NC
    574
    wow...that looks good. anyone using this same tire MT 305-35-18, with the 18x8.5 40 offset drag D's??? i see on other forums where some are using, but that tire is supposed to have a 10" rim???
  12. #11
    Stillborn's Avatar
    Stillborn is offline Cadillac Owners Enthusiast
    Automobile(s): 09 DW 4DR,AT,Recaros,metco 2.5,RX c-can,AEM-A/F, 634hp,642tq
    May 2011
    tri-state
    45
    776
    Havasusteve and Havasusteve like this.
  13. #12
    Havasusteve's Avatar
    Havasusteve is offline Cadillac Owners Fanatic
    Automobile(s): 12 TG Sedan; SOLD
    Jun 2009
    Upland, CA
    54
    303
    On order as we speak......
    Stillborn and Stillborn like this.
  14. #13
    Nov 2011
    279
    Quote Originally Posted by Havasusteve View Post
    Did you order the weld rts wheels like junkies setup? and will this setup slow top end speed down? vs lets say 18 tsw nurburgrings with 305 35 18 MT
  15. #14
    Jun 2009
    Upland, CA
    54
    303
    Quote Originally Posted by Ste_V_e View Post
    I doubt it. I was running the Z06 replicas with MT305 DR's. The difference is 17 vs. 18 (quicker rotation for better grip) and then the 45 series tire, again, for better grip.
    For my top end numbers on a 1320' (if I can ever get there) shouldnt be effected.
    That being said, TSW's are a nice lightweight wheel. I plan on getting a set for the road course...
  16. #15
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    649
    I run the TSW's for road course duty and they seem to be holding up well.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
