Results 1 to 14 of 14
Thread: Recommendations/Pictures of Sedans with wider tires???
    WBRCobra is offline Cadillac Owners Member
    Automobile(s): NONE
    Mar 2013
    11
    I've seen several posts regarding upgraded tire size combinations for the sedan, but I haven't seen any pictures of what these bigger tires actually look like on the CTS-V. I'm going for upgrades at 21st Century Muscle Cars in about a week and expecting to have 600-650 rwhp. I don't think I'll be happy with the stock 285s, so I'm thinking about upgrading. From what I know so far, I'll probably go with RE-11s, but I've heard various opinions regarding 295s, 305s, and widening the stock rear wheels (and possibly going with an even bigger tire). I am open to having my stock rear wheels widened if it will help put the power to the ground. Any suggestions regarding "the best" tire size combo? And, more importantly does anyone have pictures of what their combo actually looks like?
    Smokin80 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black Raven CTS V/Manual
    Jan 2011
    Alberta, Canada
    32
    201
    Re: Recommendations/Pictures of Sedans with wider tires???
    Check out the 1080 wrap thread of mine in appearance. The last pics I posted are with 305 30 19 rears and 265 35 19 fronts.
    They are a little shorter than stock. So if you like the beefier tire look stick with the 295 35 rears and 255 40 fronts or maybe 275 35 fronts.
    I am using the re11s by the way. So far I'm really happy with them.
    tsunami1k is offline Cadillac Owners Member
    Automobile(s): none
    Jun 2011
    33
    I'm installing some Pirelli PZero 305/30/19s in about 2 weeks on stock wagon rear rims. Ill take pictures when it's done. Got them slightly used from a friend for super cheap so it'll give me some rubber to burn up lol
  5. #4
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V A6, 752 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,110
    RE-11s on all four corners
    265/35s up front
    305/30s on back
  6. #5
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    If I really wanted to go to 305 in the rear, I'd sell the stock wheels and get some nice TSWs or such in 18s, 19s or 20s...at 10" wide rears...
  7. #6
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    Here are a few images that might help you make some decisions.
    This is a picture of a car with widen OEM sedan wheels on a 305 tire. You can see that with the wheel being the proper size, it really flattens out the tire and gives you a much wider footprint.
    Here is another picture of a sedan with a wide body that allows a 345 tire. Obviously this would require modifications. But the point is that you do have options.
    Thank you,
    Dr. Design
    D3 Cadillac
  8. #7
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,019
    When you run the rear 9.5" wheels up front, do you use spacers ?
  9. #8
    Sep 2011
    55
    Quote Originally Posted by the blur View Post
    Yes, We do. We run our D3 11mm Spacers with extended studs.
    View Raw Image" height="372" width="496">
  10. #9
    bbbeast1 is offline Cadillac Owners Member
    Automobile(s): CTS Vseries
    Sep 2012
    Biloxi, MS
    8
    Can I get alill more details on the running with 'widen OEM sedan wheels' on a 305 tire? What or how did you widen the stock wheels?
    I purchased my 2012 V sedan 'bout 6-8 months ago and like this idea of wider foot prints.
  11. #10
    Sep 2011
    55
    Quote Originally Posted by bbbeast1 View Post
    We basically take you front wheels and get them widen to a 10.5 width and mount them on the rears and take your rear wheels that are 9.5" wide and mount them to the front. We design the 11mm spacers to make the 9.5 clear the front calipers and also get the widest stance possible with out the wheel hanging out the front fender or sticking out. As far as the process of the wheels being widen, We basically split your barrel and get extended barrels weld it back together.
  12. #11
    the blur's Avatar
    Oct 2008
    NY
    1,019
    I wonder if anyone tried coupe rear wheels on the front of a sedan. That would eliminate the spacer.
    I'm running coupe rears on the rear of my sedan. They work fine on the street. I'm hesitant to try in on the track, as I don't want any rubbing, or even a chance of rubbing.
  13. #12
    Rule12b's Avatar
    Rule12b is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V Sedan
    Dec 2010
    Los Angeles
    567
    I would just like to note that the pictured set up is available for sale with tires and spacers. Please PM me for details. . .:-)
    Quote Originally Posted by Dr. Design View Post
    Hello,
    Thank you,
    Dr. Design
    D3 Cadillac
  14. #13
    Automobile(s): NONE
    Mar 2013
    11
    Thanks everyone. I ended up going with the same setup as V locity.
    265/35s up front
    305/30s on back
    I did not have the wheels widened. I think it looks great and they stick pretty well with 609 whp!
  15. #14
    Rule12b's Avatar
    Dec 2010
    Los Angeles
    567
    Hello,
    Thank you,
    Dr. Design
    D3 Cadillac
    The irony here is that both pictures are of the same exact car. :-)
  • You may not post replies
