Results 1 to 8 of 8
Thread: New Rear Differential Cooler option
    jb_bgg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black/Black V, Manual, Recaros, loaded
    Feb 2011
    Orange County, CA
    254
    My goal with this project was high quality, reliable, race-tested suitable solutions that are small, lightweight, quiet, easy to install, purpose-built, and affordable. I completed what I believe to be pretty thorough diligence on various pumps and vendors (diaphragm like Tilton & Shurflo- not designed for hot heavy gear oil), vane, spur gear, helical gear, etc.) various HX styles including plate, fans, filters, fittings, etc. Ultimately I chose and worked with Setrab’s USA subsidiary and together we assembled a kit I believe meets all the criteria above. You can do your own diligence on their products, history, and professional race team affiliations @ www.setrabusa.com.
    We selected the small 19 pass HX (6.5” x 5.75” X 4.75”) with a shrouded Spal fan pack. Spal fans are the best fan option available in my opinion; although much more expensive than the Asian imports they do provide a 3 year warranty for their product. With only 2 quarts of fluid plus HX content, cycling through the HX between 8-16 times a minute with a 1-2GPM pump this small but highly effective unit should be more than sufficient. That said, you can choose one of their larger HX options should you desire additional fluid capacity. It is possible and some people believe a fan may not even be necessary with this HX. That would need to be track-tested to confirm but that option is also available. I took a hard look at the Turbowerx pumps I felt were a very good option but decided to stick with Setrab’s 1-2 GPM unit given its very compact size and weight, overall price/performance, excellent customer support and single source vendor appeal.
    Total weight for everything in this kit (HX with fan, pump, filter, fittings, hose) is 7 lbs. Install does requires drilling; 4 holes for the pump and 4 for the HX. In my first mock-up I installed the pump and HX directly to the bottom of the spare tire well. Straight-forward install, hose and fittings are all push-lock; no worm clamps. Warmed up the hose a bit with a heat gun, little oil film on the fitting, push on firmly and done. Rest assured, this can NOT be pulled apart; I had to cut off my adjustments in line length with a razor knife. Power easily available from the rear fuse block in the battery compartment. HX needs ” space to draw air, so I used a couple rubber grommets to provide that space and cushion the HX. Pump also needed about ” spacing for the line to sufficiently clear the rear sway bar; same choice.
    The only nit for me post mock-up is the fact you can see the fan from the rear. While this is also true with the other commonly implemented option currently available, personally I wanted to eliminate that visual and keep the rear view looking as stock as possible. Without the fan I doubt you would notice the HX or pump.
    I popped the pins on the rear bumper fascia diffuser and did some rough measurements in the space between the rear bumper fascia and the body/rear bumper. There is sufficient air space and flow available and I’m about 90% certain the HX with the fan pack can be mounted vertically in that space. That presents a choice to mount the pump there as well or leave it underneath. If someone would like to take the lead on this option sooner than I get to it, please feel free. So far I’ve been unable to locate another feasible exterior location for the HX, but perhaps others may have additional ideas. Given the fan I also considered installing inside the spare well but lack of fresh air flow was the concern.
    The great news for us is pricing. Setrab USA’s normal end user “Racer Net” cost (10% below MSRP) for this kit is $933 (plus shipping.) They graciously agreed to work with us to bring this kit to this group and other V owners and offer additional discounting in a group buy scenario. In return, I agreed to handle orders and payment directly for those interested.
    Bottom line is we are getting an additional 15% (25% off MSRP) to $775 (plus shipping) for the first 10 kits sold. From kit #11 on, they agreed to another 5% discount to $720, a full 30% off MSRP. My kit counts as #1. If we don’t reach 10 kits with an initial order as long 10 do sell within 45 days from the date of the initial order, early buyers at higher prices will be refunded the difference. Full factory warranties and customer support apply.
    Component Price list PDF attached below with and without the Setrab pump should you prefer a different pump option.
    Additional desktop and install pictures including install mock-up available at: http://s1280.beta.photobucket.com/user/jb_bgg/library/ - Didn't have time to get the car on a lift for better pics at the time of this post.
    Tech specs at : www.setrabusa.com
    My email is jb_bgg@yahoo.com
    All questions, comments, suggestions and criticisms welcomed and appreciated.
    GROUP BUY Potential Interest from previous post - edit to confirm
    1. Havasusteve
    2. CJ11V
    3. bzabodyn (BZ)
    4. dbish - CONFIRMED
    5. basa ???
    6. Red Baron - CONFIRMED
    7.
    8.
    9.
    10.
    jzchen is offline Cadillac Owners Fanatic
    Automobile(s): '85 Sedan de Ville, '10 CTS-V
    Sep 2009
    Arcadia, CA
    41
    409
    Re: New Rear Differential Cooler option
    Please let me know if I should PM instead of post my questions.
    You have to drill for this install. Any way that I could just buy a kit and install? I've drilled before so maybe that I could do. It's not really clear about the hose cutting/heating. I'd be nervous about me doing that personally. (I have no experience changing the length of hoses, spark plug wires yes, but hoses no.)
    Feb 2011
    Orange County, CA
    254
    Hi JZ,
    Posting questions is fine; others may have the same one. If you're uncomfortable doing the install yourself (hoses, electrical wiring, etc.) I'd suggest letting a trusted mechanic or dealer do the install for you. Shouldn't take more than 1.5 - 2 hrs at the most.
  5. #4
    Sep 2012
    19
    How is this coming along? Can we still get the kit?
  6. #5
    Feb 2011
    Orange County, CA
    254
    Quote Originally Posted by SeeTSV View Post
    I am testing at auto club speedway this weekend and will follow up with an update afterwards. Relocated pump and hx
  7. #6
    Sep 2012
    19
    Quote Originally Posted by jb_bgg View Post
    Awesome I look forward to your writeup. Please put a link in this thread so we don't miss it!
  8. #7
    Aug 2010
    39
    19
    Any updates to this thread?
  9. #8
    Feb 2011
    Orange County, CA
    254
    Have a new implementation that works extremely well. Fully tested over 4 track days with 16 20-25 minute sessions. Please PM me for additional details.
  • You may not post replies
