Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Heat exchanger with H20 and water wetter.
    larry arizona is offline Cadillac Owners Connoisseur
    Automobile(s): 10 V 4DR,6M,Blk,2.55,airaid,160t,W4M HX & tune Eibachs
    Feb 2012
    Metro Detroit
    45
    1,347
    Lightbulb Heat exchanger with H20 and water wetter.
    Anyone try running straight distilled water and water wetter (or the Royal Purple stuff) in their factory or aftermarket heat exchanger (intercooler loop) for summer use? Should run 20 to 30 degrees cooler than 50/50 water glycol mix even with water wetter. Seems like a no brainer for summer conditions (as long as you remember to add glycol for freezing temps)
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    Re: Heat exchanger with H20 and water wetter.
    Yes, we run that combination along with a few others for some of the Challenge cars. In Vegas track surface temp was 140 and ambient was 102 and the cars were running strong!
    FYI, there is some other stuff out there too that works pretty good from NEO.
    Thank you,
    Dr. Design
    D3 Cadillac
    Feb 2012
    Metro Detroit
    45
    1,347
    Awesome thanks DR D! Going to drain and refill this weekend!
  5. #4
    May 2012
    117
    If you live somewhere that temperatures only drop say into the teens a few days a year (most of the south), then something like 25-30% antifreeze and 70-75% water works fine year round. If you live somewhere where temperatures never get below freezing, I'd run 10% antifreeze just for corrossion reasons, and 90% water, with a bottle of water wetter. The 50/50 ratio is for people living up in vermont and leaving their car out overnight when it is -30 degrees.
  6. #5
    Feb 2012
    Metro Detroit
    45
    1,347
    DR D. thanks for the heads up on the NEO keep cool. Just ordered some.
    xtra:Thanks for the feedback, goin to keep glycol to whatever is left when I drain intercooler. Will dump some wetter into the radiator for the heck of it, although I dont expect much change for engine cooling system but every bit of latent heat reduction is good. Primarily looking for intercooler efficiency.
  7. #6
    tbauer's Avatar
    tbauer is offline Cadillac Owners Member
    Automobile(s): 09 CTSV Sedan 850+HP/830+TQ
    Jan 2012
    Plano, Tx
    79
    For what it worth I posted this on the other site.
    "I spoke with Royal Purple today in requards to their Purple Ice radiator coolant additive. They recommend running a 80/20 mix minimum. 80% good municipal water or bottled water, 20% antifreeze of choice, and up to 2oz per quart of Purple Ice. They dont recommend using straight distilled water in any system that has aluminum components because of corrosion. Their product plus the 20% antifreeze will help add freeze and corrosion protection to the system while rasing the boiling point of the water. They also said not to use more than 2oz per quart of Purple Ice because it could cause foaming."
  8. #7
    Chrispy's Avatar
    Chrispy is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS Luxury
    Apr 2012
    Ontario, Canada
    553
    Has anyone logged before and after swapping in water versus the stock setup from an IAT2 perspective?
    I think a 160 stat, fan tuning and doing the changes above would make a really nice difference in IAT2 temps for most cars.
  9. #8
    Feb 2012
    Metro Detroit
    45
    1,347
    Chris, That is a good idea to datalog, but honestly any increase in intercooler efficiency has to provide cooler IAT2's. Even if the delta for 50/50 glycol to h20 and wetter is 10 degrees (test data showes up to 30 deg) in the intercooler loop, that is significantly better for IAT2. My intentions is to increase my intercooler loop for max efficiency and glycol is awful for heat transfer, I don't drive my V in freezing temps and for $12 in NEO keep cool and free water, I am doing it
    Simply going to add glycol in the fall for storage and back to water and wetter in the spring.
    Other than throwing a few ounces into the radiator, I am not planning on decreasing glycol content in the engine cooling loop.
  10. #9
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    553
    Cool good stuff...I was thinking the stat and fan programming would help with airflow across the heat exchanger and thus further improve cooling as well.
    How difficult is it to drain and refill the intercooler loop?
  11. #10
    Feb 2012
    Metro Detroit
    45
    1,347
    Easy to drain stock IC system (a little messy), just pull hose off IC pump and run the car for a few seconds. I also have a W4M IC too. Fan programming will help your stock IC from getting more airflow at low speeds but a 160Tstat won't do anything for the IC loop. Also a heads up, consider a catch can system for the PCV system, the blow by under boost on the LSA likes to foul up the IC exchanger inside the Super Charger case. I picked up a moroso catch can and its a nice easy install and keeps oil out of the supercharger area. An oil coated IC exchanger kills efficiency.
  12. #11
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    553
    Quote Originally Posted by larry arizona View Post
    Thanks...do you have a part number or link to the catch can?
    The 160 stat just allows you to program the fans at a lower temp while still letting the thermo open
  13. #12
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    553
    duplicate...please remove
  14. #13
    Feb 2012
    Metro Detroit
    45
    1,347
    chris,
    Moroso 85603 is the catch can for the V (black). I think 85602 is the same in silver. I got it from JEGS for like $131 plus shipping. I too have the 160 tstat and fan programming, engine does run cooler.
  15. #14
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    553
    Awesome thanks! Going to order one today
  16. #15
    Feb 2012
    Metro Detroit
    45
    1,347
    Chris, I know the weak LS PCV system is well known and you will be happy you add a can. Most are not aware and its a cheap fix. Moroso did a good job locating it for easy service.
  • You may not post replies
