Page 7 of 8 FirstFirst 12345678 LastLast
Results 91 to 105 of 115
Thread: Pilot Super Sport alternate sizes
  1. #91
    dgman2 is offline Cadillac Owners Member
    Automobile(s): 2011CTS-V / AT Sedan, Black w bl wheels
    Jun 2011
    Hammond, La.
    52
    Re: Pilot Super Sport alternate sizes
    I think I found my combo, but I'll have to wait until its time to change tires.
    Michelin Pilot super sport rear 295/35/19 and front 265/40/19. Better tire than stock in every way and 300 tread wear versus 220. These are stock on the new BMW M5. The small difference in sizes should not set off any codes and will also make the car look better due to a slightly wider stance.
  2. #92
    RapidRob's Avatar
    RapidRob is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V Black/Black, manual
    Dec 2008
    Seattle area
    1,347
    ^^^ - No issues with the PSS 295/35/19's on the oem rear wheels?
    Rob
  3. #93
    Jun 2011
    Hammond, La.
    52
    Since many are running 305/30/19 with no problem, 295/35/19 should be fine.
  4. #94
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Yeah, the 295 on the stock wheel will be fine...
  5. #95
    Phil Raymond is offline Cadillac Owners Member
    Automobile(s): CTS V 2011 Coupe
    May 2011
    75
    I just had the 265/40/19 and 295/35/19 super sports put on my car yesterday (but I have the coupe). I would have preferred the 305s but just could not get past making the wheel well even less full...
    These tires are better fitting than the OEM sizes IMHO...I usually go up two sizes when replacing OEM tires on my cars but only one in this case. I don't understand being afraid to go up only one size...do you really think they don't design in any margin???
    Good luck. Tires are expensive...have your dealer match tirerack and there is also a $100 GM rebate when purchasing through the dealer.
  6. #96
    Jun 2011
    Hammond, La.
    52
    Quote Originally Posted by Phil Raymond View Post
    I agree. I also have a problem with anything that would increase the tire/ fender gap. Thanks for the
    feedback. Those will be my replacement tires, starting with the rear. You are right about them not being cheap,
    but they are still cheaper than what I had on my vette and ill have a nice discount from one of my favorite sources. I will check on the rebate you mentioned; is that per tire or per set?
  7. #97
    larry arizona is online now Cadillac Owners Connoisseur
    Automobile(s): 10 V 4DR,6M,Blk,2.55,airaid,160t,W4M HX & tune Eibachs
    Feb 2012
    Metro Detroit
    45
    1,347
    After looking at the 295/35/19 at 27.1 and 255/40/19 at 27.1. I think that combo is perfect. 265/40/19 is cool too. After lowering my sedan I don't want anymore gap to return to the wheel well.
  8. #98
    Feb 2012
    Metro Detroit
    45
    1,347
    only negative in the 295/35/19 is you lose 1/32nd of tread depth (9/32 versus 10/32). Thanks Michelin Man !
  9. #99
    May 2011
    75
    Quote Originally Posted by dgman2 View Post
    I just pulled out the rebate form the service guy gave me...told me $100 for my tires but looking at the rebate there are two levels of rebate - $50 and $100. The Michelins are in the $50 bracket and you have to buy 4 tires. The rebate is good thru September...
    Now I'm calling my dealer in the AM and making them credit me the $50...I should have know because the service rep also said they replaced the brake pads in addition to the rotors (I had the TSB done at the same time) and I had to call back today to ask the tech if he really did...he did not.
    So if you buy the 4 make sure you bring in the Tirerack rebate to get them to price match it.
  10. #100
    Feb 2012
    Metro Detroit
    45
    1,347
    Phil, If you don't mind telling us, what was your price on the tires in the end?
  11. #101
    Jun 2011
    Hammond, La.
    52
    Yep, the TSB replaces rotors... Not pads. I know it's theoretically not the right thing to do, but I'll be doing rears only untill I need fronts also. The difference in size specs between the 295/35/10 and 255/40/19 is well within the parameters to NOT cause any problems. As you said, they are not cheap, so I'll use up my
    fronts before replacing them.
    With the discount I'll be getting, the rebate will not apply; I just checked on that.
  12. #102
    Jun 2011
    Hammond, La.
    52
    My price won't be a fair comparison, because illbe getting them at dealer cost. I don't remember the exact numbers I was quoted, but I think it was 390 ish for the rears and 360 ish for the fronts.
  13. #103
    Oct 2011
    64
    Can we get some pics?
  14. #104
    Automobile(s): ZIP
    51,885
    I will always use the Tire Rack because they have been serving me well for over 20 years. And since they are the reason everyone price matches, I'll spend a few more bucks to keep them going. Plus, their tests, comparisons, buyer feedback pages are invaluable. We have $70k cars. We're talking about tires that cost more than rims. While I like saving money, I'm not going to sweat a couple bucks a tire...
  15. #105
    Jun 2011
    Hammond, La.
    52
    Quote Originally Posted by larry arizona View Post
    Tread life on the Pilot Super sport is much better than our stock tires (300 v/s 220), so tread debt shouldn't be an
    issue; it is obviously a tougher compound.
  • You may not post replies
