Page 7 of 8 FirstFirst 12345678 LastLast
Results 91 to 105 of 108
Thread: Stick or Auto
  1. #91
    CadV is offline Cadillac Owners Connoisseur
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    Re: Stick or Auto
    Quote Originally Posted by CSX View Post
    Most C5 and C6 Corvette owners I've spoken too also say that auto 'Vettes put down quicker times than their manual counterparts as well.
    I remember that talk and ever person I raced with an auto I beat with a manual.
    With the car being the same there is no way an auto will beat a manual if the driver is good.
  2. #92
    gotapex is offline Cadillac Owners Member
    Automobile(s): Alas, none yet
    Oct 2008
    58
    Re: Stick or Auto
    Quote Originally Posted by CadV View Post
    It's possible with a turbocharged vehicle. There's no boost loss between gears with the automatic, and you can also brake launch to build boost from launch. That's why the Porsche 997 Turbo is faster in auto than manual.
  3. #93
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Re: Stick or Auto
    Hey Mr. Hypothetical, when are automatic and manual versions EVER equal??
  4. #94
    Dec 2004
    Leesburg, Florida
    2,190
    Re: Stick or Auto
    Here's some more fuel for the fire:
    Most of the magazines have a rule in their testing procedure that requires them to test manual transmission cars by lifting off the gas, pressing the clutch, then reapplying the gas. I assume this rule is to prevent testers from achieving unrealistic times by "speed shifting", which would not be representative of real world acceleration. I always assumed that cars like the ZR-1, Cobalt SS and CTS-V would be tested using the "No-Lift Shift" feature, since GM designed this feature for use and would not be considered "abuse". I saw a writeup in Car & Driver this month on the Cobalt SS however, that specifically mentioned that they did NOT use the No-Lift Shift in the test due to the rules. Here's the quote:
    Quote Originally Posted by Car and Driver Magazine
    Had we used the no-lift shift feature built into the Cobalt SS, it would have been quicker than the Mazda through the quarter-mile, but our test procedure requires using the clutch pedal and lifting off the throttle to shift.
    So the question now becomes "Are the 0-60 times for the 6MT in the magazines using the No-Lift Shift or not?"
  5. #95
    Ketzer's Avatar
    Ketzer is offline Cadillac Owners Fanatic
    Automobile(s): '14 Wagon
    Feb 2008
    Eads, TN.
    297
    Re: Stick or Auto
  6. #96
    Dec 2004
    Leesburg, Florida
    2,190
    Re: Stick or Auto
  7. #97
    b4z is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Standard SrX grey/black 2006 GTO
    Mar 2003
    Chas. SC
    54
    1,795
    Re: Stick or Auto
    That's just dumb. I understand using the clutch and lifting because that is the intended design of most manual transmissions and will lead to longevity.
    But when a company includes a feature specifically designed to not lift, why wouldn't you use it.
    Car and Driver's decision is just dumb.
    Maybe they should test all automatic transmission cars by lifting before each gear change? LOL.
  8. #98
    Dec 2004
    Leesburg, Florida
    2,190
    Re: Stick or Auto
    On one hand I see C&D's point- they're trying to compare the strength of the engine and drivetrain on equal footing by not using the NLS, but on the other hand I agree with you and think it's dumb. The feature was built into the car for the purpose of improving acceleration, so not using it is like taking the belt off the ZR-1's Supercharger to make it "fair" against the Ferrari.
    Motor Trend is the only one that mentions the NLS in their testing, and posted a 4.1 0-60 for both transmissions. Looks like when it's all said and done, both are equal and it comes down to driver skill.
  9. #99
    Mar 2004
    5
    Re: Stick or Auto
    If I were leaning Auto, I'd prolly pick up a CLK63 Black Series. It's a better car. What makes the V cool is that you can get a stick (and it's not detrimental to the overall design, like the stick on the E60 M5 was).
  10. #100
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    Re: Stick or Auto
    Quote Originally Posted by thebigjimsho View Post
    I said with the car being the same as in same CAR.
    But you are right auto and manuals are not equal hahaha
  11. #101
    Luna. is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Stealth Gray CTS-V, 2009 Black CTS-V
    Jun 2005
    CA
    3,571
    Re: Stick or Auto
    Quote Originally Posted by Cadillac Tony View Post
    LOL Tony...you are so very evil...
  12. #102
    Automobile(s): ZIP
    51,885
    Re: Stick or Auto
    Do manual and auto versions ever have the same curb weight, gear ratios, etc...???
  13. #103
    caddynoob is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2008
    150
    Re: Stick or Auto
    Let's not forget that the tires on the auto and manual cars that they tested might have different level of wear. Though in acceleration test it is probably less of an issue.
    At the end, performance wise they are very close.
  14. #104
    Jan 2005
    Palmdale, CA
    64
    98
    Re: Stick or Auto
    The Auto and Manual have different rear gears also.
    The Auto is 3.23 to 1. The Manual is 3.73 to 1. Using the proper gear ratios for each tranny and rear tire size (285/35-19) provides the following numbers:
    Automatic: 2000 RPM in sixth = 71.2 MPH
    2250 RPM in sixth = 80.2
    2500 RPM in sixth = 89.1
    Manual: 2000 RPM in sixth = 65.6 MPH
    2250 RPM in sixth = 73.8
    2500 RPM in sixth = 82.0
  15. #105
    HPCC is offline Cadillac Owners Member
    Automobile(s): NONE
    Dec 2003
    L.A.
    74
    Re: Stick or Auto
    ^ Hmmm...the numbers indicate the manual has more of an overall mechanical advantage gear ratio-wise, yet the auto maintains parity to a slight acceleration advantage. Could the auto's torque converter be a factor?
  • You may not post replies
