Results 1 to 8 of 8
Thread: High Capacity Oil Filter Options
    explorer7700 is offline Cadillac Owners Member
    Automobile(s): 2005 Black Cadillac CTS-V
    Mar 2006
    Cleveland, Ohio
    36
    Could anyone give me some options for a higher capacity oil filter for the V?
    Jun 2010
    Los Angeles, CA
    46
    303
    Re: High Capacity Oil Filter Options
    AC Delco PF48 is taller IIRC
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    All I'll say is this:
    There are things that are helpful to change on the car and there are things that are insignificant. An oil filter that is 1-2ozs larger is insignificant. Don't ponder these things too much and just focus on the more meaningful stuff.
  5. #4
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Yeah. Kinda curious as to what the application would be. OP, what are you up to?
  6. #5
    Z71's Avatar
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    Quote Originally Posted by explorer7700 View Post
    What do you mean by "higher capacity oil filter"? More oil capacity or hold more contaminates?
    I agree a few oz's more oil just for the sake of having a few more oz's of oil will do nothing for your engine. If on the other hand you want a better oil filter, that filters better and has greater dirt holding capacity then here is one that does; Premium-Grade Full-Synthetic Media Oil Filter
    Do not rely on physical dimensions alone. Just because a filter may appear larger it no indication it is a better filter.
  7. #6
    May 2013
    Naples, FL
    692
    Quote Originally Posted by Z71 View Post
    If you use the Amsoil guide, THIS is the correct filter. It's what I've been using and does the trick.
  8. #7
    Mar 2006
    Cleveland, Ohio
    36
    Thanks. I should have said high quality filter. Do you change the AM Soil only every 15k? Also do you use AmSoil oil?
  9. #8
    I'mAllIn is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Wagon
    Sep 2012
    Piperton, TN
    17
    I wondered the same thing for a different purpose. With headers, there's very little filter left to grip to install or remove. Changed oil this weekend for first time with headers and it was a major PITA. A little taller filter would make all the difference. Any ideas?
  • You may not post replies
