Results 1 to 12 of 12
Thread: Spray-On 3M Coating
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,788
    Spray-On 3M Coating
    I went ahead and did it for an upcoming track session and was happy with the results. It peels off like Plastidip too. It actually gives an orange peel texture. All you need is the spray can, for $25, and not the other things really. You can put it where you want it too, as opposed to having a sheet of covering to deal with. It says it will last up to a year too. I'll report back after some rain and track use too.
    Tedboss1's Avatar
    Tedboss1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTSV Auto
    Jun 2009
    Montreal
    1,077
    Re: Spray-On 3M Coating
    Is this the coating that you used?
    http://www.autozone.com/autozone/lan...der-spray-film
    warmwater is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Jun 2013
    38
    OK that is just awesome I want, please let us know how it works out
  5. #4
    vagondr is offline Cadillac Owners Fanatic
    Automobile(s): '13 CTS-V wagon WD graphite 6 MT Corsa Sports CAI
    Sep 2012
    central NJ
    73
    180
    I coated the front bumper/grill area back to the wheel wells. Not affected by rain and bugs are easily removed. The full kit makes masking and application easier. Buy some extra tape because our grill/light configuration takes a lot of masking. See the Youtube videos before proceeding. It's not as easy as it looks to apply in the recommended pattern because the surface in the bumper region is complex, not flat and is vertical. The demo is an application to the hood. Don't apply enough and you may not be able to remove it - too much and it will run. My problem was the latter and I was horrified. That said it is very forgiving. Don't panic. Go through the curing process as directed. Two days in dry weather with sun exposure - maybe four in humid conditions. It cures very shiny and most flaws including runs seem to disappear. Unfortunately, I just had to point out a defect to my wife who then noticed others. I have yet to have any other negative comments. You'll spend most of your time masking and be sure to remove the tape immediately after application. You'll have to wait a few days to drive and see the results. They under estimate the coverage area per can so you won't run out. I'm going to use what's left on the rocker panels. I don't collect bugs on the hood and chrome protects the edge so I'll leave it untreated. I'm satisfied. Just hope it can actually be removed.
  6. #5
    neuronbob's Avatar
    neuronbob is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 6MT V wagon, OBM, 2009 silver V sedan (traded)
    Dec 2007
    Cleveland area, OH
    48
    4,526
    Cool. I'll use it on my S2000 since it doesn't have a clear bra yet.
  7. #6
    Feb 2011
    Northridge
    9
    very cool. i'm sure it beats blue tape for track events.
  8. #7
    Rule12b's Avatar
    Rule12b is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V Sedan
    Dec 2010
    Los Angeles
    567
    To the OP, can you post a link or something to the product you used?
  9. #8
    neuronbob's Avatar
    Dec 2007
    Cleveland area, OH
    48
    4,526
    Quote Originally Posted by Rule12b View Post
    It's in post #2. That stuff has made the rounds of the Intertubes the last couple of months.
  10. #9
    201Vwagon is offline Cadillac Owners Member
    Automobile(s): 2011 V Wagon, 2012 V Coupe, 2013 XTS AWD
    Aug 2012
    58
    I used this on my rear lower bumper to try out since with the 305 DR's it throws stuff up. It works great but then I thought I try and take it off. It didnt peel off like pasti dip. I had to use a cleaner and bust my ass to get it all off. I don't think I put it on thick enough. I sprayed some real good coats too.
    I'm going to try a smaller section and coat it even more.
  11. #10
    Rule12b's Avatar
    Dec 2010
    Los Angeles
    567
    Ok this product is a pass.
  12. #11
    Feb 2011
    Northridge
    9
    how is plastidip on this application? I've only seen it being applied in videos. does it hold up to track events?
  13. #12
    Aug 2012
    58
    I use the plastidip before in the same spot when using the DR's and the only issue is I have a black patch which looks funny but peels right off. When I get around to it ill try the clear stuff on the daily driver and coat it real well. Then see if it peels off.
  • You may not post replies
