Results 1 to 8 of 8
Thread: Transmission Fluid for 6MT
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    Just want to confirm this service manual I found is correct. It says the 6MT transmission takes 1.9 qts of GL5 75W90 gear oil. Is this right? Seems weird the transmission is using the same gear oil as the rear diff.
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    711
    Re: Transmission Fluid for 6MT
    Well it is a gearbox
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Completely wrong
    The tr6060 takes dexron III atf which no one (except gm) can actually produce anymore.
    Gm actually makes dex3 under what they call now manual transmission fluid( I still have 4-5 quarts)
    It's $8-12 iirc
    Definitively don't use gear oil.
    I'm looking to get rid of it, if you decide to. Buy some pm me.
  5. #4
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Yeah, what manuals are you looking at?
  6. #5
    May 2013
    Naples, FL
    692
    I have a pdf of a 2008-2009 CTS/V service manual (been shared by a member with a ton of other info on Google Drive). The problem is the PDF doesn't contain a table of contents so finding specific items is a biatch. I looked at the wrong transmission...it also lists an Aisin AY6 which takes gear oil. In another section there's the Tremec 6060 that lists 3.65 qts of GM part number 88861800.
  7. #6
    jb_bgg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black/Black V, Manual, Recaros, loaded
    Feb 2011
    Orange County, CA
    254
    GM also sells DEXIII in one gallon containers. Pick up one of those, you'll need nearly all of it.
  8. #7
    Torxila's Avatar
    Torxila is offline Cadillac Owners Enthusiast
    Automobile(s): 1 of 1 Evo Green Coupe 6m, with RB9
    Aug 2008
    Farmington Hills MI
    69
    568
    Royal Purple Synchromax in mine.
    2010 Tremec TR6060 (MG9) 6/5/2009
    Type: Rear wheel drive, six-speed manual overdrive transmission
    Engine range: LSA super charged 555hp
    Maximum engine torque: 551 lb-ft ( 747 Nm )
    Maximum gearbox torque: 560 lb-ft ( 760 Nm )
    Gear ratios: MG9
    First: 2.660
    Second: 1.780
    Third: 1.300
    Fourth: 1.000
    Fifth: 0.800
    Sixth: 0.630
    Reverse: 2.900
    Final Drive Ratio: 3.730
    Maximum validated gross vehicle weight: 4255 lb ( 1930 kg )
    Case material: Aluminum
    Center distance: 85 mm
    Fluid type: Texaco ATF Type III 1863
    Transmission weight: Wet: 65.8 kg (145.1 lb )
    Fluid capacity (approximate): Dry: 3.8L +/- 0.06L (4.0 qt) 128 oz. +/- 2 oz, internal pump
    Power take off: No
    Applications: Cadillac CTS V
  9. #8
    May 2013
    Naples, FL
    692
    I just bought a gallon of Amsoil Signature Series ATF. We'll see how that does.
  • You may not post replies
