Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 100% stock getting popping on decel
    nunii is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ctsv
    Jul 2007
    Brooklyn ny
    120
    Why is this happening ?
    One more thing lately the exhaust sounds much deaper since I got the car last month only has 700 miles on it is this normal?
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Yes. The carbon buildup will do that. As for the popping, not sure. I've listened to exhaust popping for years in one way or another for decades so I'm pretty tone deaf to it.
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    Ignition related..... Perhaps a Bad or failing coil pack.. Bad wire or plug... Perhaps not enough juice to burn the remaining fuel completely?
  5. #4
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    562
    Re: 100% stock getting popping on decel
    it's rich (unburnt fuel) for some reason. Could be faltering ignition allowing cylinders to not burn properly, it could (more likely) be a sensor going bad, causing the ECM to otherwise do weird things, or it could be an exhaust leak throwing off O2 sensors - again resulting in excess fuel that's being burned off in the exhaust. A lot of people get it from exhaust mods where the tune is not adjusted - they think it sounds cool. In a factory car, it suggests again excess fuel for whatever reason.
    In either case, it will eventually cause your catalytic converters to die young.
    I'd have the dealer hook up a scan tool and see what pops up.
  6. #5
    Jul 2007
    Brooklyn ny
    120
    Could this have anything to do with me disconnecting the battery cause the car felt very sluggish !
  7. #6
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,840
    Quote Originally Posted by nunii
    It could if you haven't driven it much since. It's got to relearn the A/F as you drive.
  8. #7
    Zhariak is offline Cadillac Owners Enthusiast
    Automobile(s): 2015 Mercedes CLS63 AMG S
    Feb 2008
    Calgary, AB
    30
    877
    Popping is bad?
    Both my 12 and my 13 V did this... My 13V is doing it more then the 12...
    My 13 V does it every time I change gears, and does it plenty on deceleration.
    I know nothing about cars, but I didn't think it was bad? I kinda thought the sound was ****ing awesome and a bit bad ass
    And actually, I noticed that if I have a bit of fun with the vehicle (drive "spirited" for a bit), afterwards it does it lots when going back to driving normally.
    Running 92 gas at altitude of 1,000 meters
    And just to add...
    It's the pop that people hear that cause the initial heads to turn to see what's making the sound. Then the grin/smile/raised eyebrows when they see the car
  9. #8
    Jul 2007
    Brooklyn ny
    120
    Quote Originally Posted by Trapspeed View Post
    Only drove about 10 miles since I disconnected the battery I guess that mite be ill drive a little more and see what happens. Thank you!
  10. #9
    ClarkkentCTSV is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Thunder gray CTS V
    Jun 2012
    South Florida
    34
    215
    Drive the car for atleast 60mi. This should help the computer relearn and adjust the a/f. Sounds like its running rich causing unburned gas to ignite in the hot exhaust.
  11. #10
    BigDog001's Avatar
    BigDog001 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Black Diamond V Coupe
    Jul 2011
    Florham Park, NJ
    205
    I don't think it is unusual at all - I get it all the time - and actually like it!
  12. #11
    Topless vette's Avatar
    Topless vette is offline Cadillac Owners Fanatic
    Automobile(s): CTS V
    Jul 2012
    Ontariio Canada
    232
    not unusaull at all. normal. go with it.
  13. #12
    ENVIOUS V is offline Cadillac Owners Member
    Automobile(s): 2012 Radiant Silver CTS -V, 1987 Buick Grand National
    Nov 2012
    SoCal
    51
    Normal as well just drive it.
  14. #13
    jwbhole is offline Cadillac Owners Member
    Automobile(s): 2013 CTS-V Wagon ThunderGray, Six Speed
    Oct 2012
    Philadelphia suburbs
    52
    41
    I had a bit of popping (aka backfire) with stock exhaust. Changed to Corsa sport axle-back with 400 miles on the car. It pops more and it's awesome. Go with it.
  15. #14
    LeeH's Avatar
    LeeH is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Coupe
    Jan 2013
    Pequannock, NJ
    57
    67
    Quote Originally Posted by jwbhole View Post
    What he said, except I had 5K miles on mine.
  16. #15
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Depends on how much we're talking about, but generally this is normal and not immediately noticeable until you get some aftermarket mufflers. My car 'pops' on nearly every shift, and nearly every decell while in gear.
  • You may not post replies
