Results 1 to 15 of 15
Thread: Big Failure all at once... help
    sarasota_krash is offline Cadillac Owners Member
    Automobile(s): 2013 CTS-V Sedan, Black Diamond & 2013 Escalade Hybrid Black
    Jan 2012
    Sarasota, FL
    63
    Hey guys,
    So I lost power steering, ABS, traction control and power e-brake all at once. I had the battery terminal disconnected for about 2 days. What could have gone wrong with all these going at once? Any ideas???
    Thanks in advance.
    Mike
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Quote Originally Posted by sarasota_krash
    Hey guys,
    Thanks in advance.
    Mike
    Did you check fuses?
    Dec 2012
    52
    Hey guys,
    Thanks in advance.
    Mike
    Make sur the battery is kip to full charge low voltage will drive these new cars crazy.
  5. #4
    Jan 2012
    Sarasota, FL
    63
    Re: Big Failure all at once... help
    I just noticed I don't have an AC belt. So that would explain the AC not working but would any of the other things be combined with this problem?
  6. #5
    Dec 2012
    52
    What is the year I can look up belt routing but it doesn't look like that would cause the problems unless it took some wiring harness with it when the belt came off
  7. #6
    baabootoo's Avatar
    baabootoo is online now Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,778
    So you lost the AC belt from disconnecting the battery????? The AC belt only runs the compressor too. What did the dealer say about it? Is some of the story missing here?
  8. #7
    Mar 2010
    Detroit, USA
    12,709
    Sarasota_krash, I'm sorry to hear this! I hope you've been finding the community's DIY advice helpful so far, and please contact me if you would like any assistance working with your dealership or researching any applicable recalls to your specific vehicle. I'm available via email at Katie_Lucille@gmexpert.com and happy to explore your next steps with you at any point in the process.
    Best,
    Katie
    Cadillac Customer Service
  9. #8
    Jan 2012
    Sarasota, FL
    63
    Thanks for the input everyone. It was a computer related issue which got fixed with a simple flash at the dealership. The AC lost a belt. Unrelated to that issue, I disconnected my battery when I was hardwiring my escort radar detector. The plugging back in of the battery caused the computer to freak out and disconnect a module which controls ABS, traction, steering and e-brake.
    Gone are the days when a guy can work a little on his own car. Now the dealership knows all about it... LOL
  10. #9
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,778
    Good, and now you taught us as well! Thanks. Katie got a copy on this?
  11. #10
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    Probably when hooking back up the battery, it flagged low amp/voltage to the modules and they had internal dtcs set. The dealer probably just had to clear the low voltage codes from the modules and they fired right back up. They can be reset with a tech2 or scan tool that can do a MASS dtc module reset..
    Disconnecting the battery though would not cause the belt on the ac to come off.. Not sure what is going on there....
  12. #11
    Mar 2010
    Detroit, USA
    12,709
    Sarasota_krash, thanks for posting your resolution! (And thanks for the heads up, baabootoo!) I'm glad your dealer was able to determine the cause and provide the fix for you. If you ever have questions in the future, I'm just an email away.
    Best,
    Katie
  13. #12
    Aug 2012
    709
    Glad to hear it was relatively simple and painless to fix. Unlike other horror stories you read about here
  14. #13
    vagondr is offline Cadillac Owners Fanatic
    Automobile(s): '13 CTS-V wagon WD graphite 6 MT Corsa Sports CAI
    Sep 2012
    central NJ
    73
    180
    For almost any car service you're supposed to disconnect the battery first. You must have the ignition off and disconnect the negative terminal. The computer then becomes stupid and there is a sequence to follow when you reconnect the battery to avoid driveability issues. It's something like leave the ignition on for three minutes, then start and idle for a few minutes. Hasn't anyone replaced a battery or recharged one without issues?
  15. #14
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,490
    It's crazy to have to take the car to the dealer just to replace a battery.
    When I hard wired my radar detector all I did was pull a fuse where I was messing around.
  16. #15
    Dogbreath is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Dec 2011
    Peoples Republik of MD
    62
    65
    I replaced the battery in my '09 with no issues.
  • You may not post replies
