Results 1 to 11 of 11
Thread: Tires skipping in reverse
    Steve BigD is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V black diamond coupe
    May 2012
    Clinton, New Jersey
    68
    35
    This is the first winter for my 2012 CTS-V coupe and now that the temperatures have gotten colder I have noticed that when its less than 40-50 degrees and the ground is wet that when I back out while making a tight turn with the steering wheel near lock the front tires feel like they actually skip and make a juddering in the front end. Itís like the tire rubber is being dragged rather than rolling. If I straighten the wheel a bit it goes away. This only happens in reverse.
    This also occurs in the dry if the temperature is below 40 degrees although it is much less. Is this because the tires are summer only? I had factory summer Dunlop SP2000 tires on my BMW 540 for two winters and never noticed this condition. I just want to be sure there is nothing wrong with my car and I will probably have to get snow tires or drive my truck in the cold temps.
    Thanks,
    Steve D
    2012 Black Diamond coupe
    Nebxrayman is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe 2011
    Dec 2010
    Lincoln, Nebraska
    1
    I have had my Coupe CTS-V for two years now and it does the same thing. I also notice it when it is cold more than not. Also more when the driveway is wet. Not ice so much, as I don't drive it in that situation. I have always just chalked it up the anti lock system. I have not asked Cadillac service about it.
    smackdownCTSV's Avatar
    smackdownCTSV is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V BDE (Sold) 2010 CTS-V Red (Traded)
    Jun 2011
    1,959
    Re: Tires skipping in reverse
    "Normal" given the tires and suspension/alignment.
  5. #4
    simgolfer's Avatar
    simgolfer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V sedan, manual, silver/ebony, airaid, SW catback
    Jul 2011
    Elk Grove, CA
    228
    I have a sedan and noticed the same problem. But after I replaced the stock PS2s with Hankook V12 evos, have not had any issues.
  6. #5
    Dogbreath is offline Cadillac Owners Member
    Dec 2011
    Peoples Republik of MD
    62
    65
    I bought our V last Dec. and thought that the skipping and noise was a problem. Once the temps rise, the noise goes away. Bottom line, don't worry about it, nothing is wrong.
  7. #6
    May 2012
    Clinton, New Jersey
    68
    35
    Thanks guys. I'll rest easier.
    Steve D
  8. #7
    Mar 2010
    Detroit, USA
    12,711
    Quote Originally Posted by Steve BigD View Post
    Steve D
    Steve & Nebxrayman, I'm happy to see the community feedback helped you! If you do have any lingering concerns, I'd recommend checking with your dealership's service department, and if you would ever like me to check my resources for you, please email me at Katie_Lucille@gmexpert.com.
    Best,
    Katie
    Cadillac Customer Service
  9. #8
    Tedboss1's Avatar
    Tedboss1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTSV Auto
    Jun 2009
    Montreal
    1,077
    Every year when weather turns cold we get the same questions about this problem:
    http://www.cadillacforums.com/forums...ing-right.html
    http://www.cadillacforums.com/forums...l-binding.html
  10. #9
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Yep, normal operation. Don't sweat it, guys...
  11. #10
    daedelus77 is offline Cadillac Owners Member
    Oct 2012
    Columbus OH
    4
    Glad I found this thread. I just lowered mine and then noticed this when temps dropped. Couldn't find anything rubbing. Phew!
  12. #11
    marktanner is offline Cadillac Owners Enthusiast
    Automobile(s): 2017 ATS-V Sedan, Vector Blue/Black, 6MT
    Aug 2008
    Atlanta, GA
    883
    This is totally normal for the PS2s. Happened with my '08 CTS with FE3 and PS2s as well. Now that I have Continentals, problem has disappeared.
  • You may not post replies
