Results 1 to 7 of 7
Thread: Question about the headlight switch (this may be a Canadian car thing. not sure)
    ctsVeteran's Avatar
    ctsVeteran is offline Cadillac Owners Member
    Automobile(s): Blue Diamond Tricoat '09 CTS-V
    Nov 2012
    40
    31
    Can the lights be set to "off" and not just auto?
    I hate seeing my HID's ignite for nothing when i pull in and out of my garage, or am sitting under an overpass waiting for a light or something ect... Fact is i rarely drive at night with my car so if i can save some of the ballasts' life.
    V Wagon is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Wagon-Raven Black, manual, satin graphite wheels
    Jun 2011
    Clawson, MI
    35
    374
    Re: Question about the headlight switch (this may be a Canadian car thing. not sure)
    You can twist the thing and turn the lights to off but you have to do it every key cycle.
    thegraham77 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS V Coupe Thunder Gray ChromaFlair
    Jul 2012
    Iowa
    67
    I 100% agree. I had an '06 CTS that also had auto lights BUT...I had the choice to turn them to the auto setting. They were off by default. Not like my V where it's on auto no matter what. It'd be nice if Cadillac would change that on future cars.
  5. #4
    Mar 2010
    Detroit, USA
    12,711
    CtsVeteran, are you a current resident of Canada? If so, then I found the contact info for the Customer Service team nearest you. GM of Canada agents are available via phone hotline at 800-263-3777, M-F 7:30am - 11:30pm, Sat 7:30am - 6:00 EST.
    If I misunderstood the thread's subject line, I apologize!
    Katie
    Cadillac Customer Service
  6. #5
    vagondr is offline Cadillac Owners Fanatic
    Automobile(s): '13 CTS-V wagon WD graphite 6 MT Corsa Sports CAI
    Sep 2012
    central NJ
    73
    180
    I wish we could make our own decisions as to when lights turn off and on, chimes and beeps warn us about who knows what, how long I can utilize the accessory mode, and when the doors lock. I just automatically twist the knob clockwise and hold it when starting. Just minor issues with an otherwise awesome car.
  7. #6
    ctsVeteran's Avatar
    Nov 2012
    40
    31
    The Audi was nice like that.. All options you can customize through the OBD port with a laptop.
    Things ill miss are:
    Turn off seat belt chime + warning light - (i ALWAYS wear my seat belt. But with a manual car when i got to a destination and didnt had to stay in the car but removed my seatbelt to be more comfertable.. the damn ting would chime to no end.. even if i was parked in neutral with the hand brake on!!!)
    One touch unlock - not as big a deal i guess since you dont have to press unlock anymore. you just have to be near the car with the key fob
    Open / Close windows + sunroof with the key fob - just by holding lock or unlock i could open close the car windows. Great for when you realize the sunroof is open and your on your way to bed.
    Headlight settings - you can chose some options as to what lights turn in in various settings other than full on.
    At the end of the day though... Ill forget about those REAL quick when i hear the engine purr
  8. #7
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    My 2009 CTS-V has an on/off position on the headlight stalk (right next to the auto position). It is marked with the circle intersected by a bar (standard on-off marker). I will check my wife's 2013 coupe to see if her's has a similar position when she gets home (I assume it does). As indicated by V Wagon, this is a spring-loaded position and must be activated each time the car is started. You can, however, select the running lights position, which is not spring-loaded and will not activate the HID ballast. Unfortunately, selecting this position will turn on the running lights at all times.
  • You may not post replies
