Results 1 to 5 of 5
Thread: passenger side a/c seat and temp (up/dwn) won't work.
    Stillborn's Avatar
    Stillborn is offline Cadillac Owners Enthusiast
    Automobile(s): 09 DW 4DR,AT,Recaros,metco 2.4,RX c-can,AEM-A/F, 634hp,642tq
    May 2011
    tri-state
    48
    776
    i tried locating the fuse that would be the culprit in the owners manual but to no avail.
    i was hoping a tech or anyone having the same issue could chime in. any help in the
    right direction would be appreciated. to clarify the heated seat works, as well as the up
    temp button.
    Thrill6's Avatar
    Thrill6 is offline Cadillac Owners Fanatic
    Automobile(s): 11 CTS-V Sedan, 07 Corvette Convertible
    Oct 2010
    Columbia, MD
    237
    Re: passenger side a/c seat and temp (up/dwn) won't work.
    I've had the center piece out and its really an electronic part. There are circuit boards on it and they are all interconnected with each other. There is only one connector between it and the rest of the car. I would guess that you need to replace it and hopefully you are still under warranty because it's a pretty expensive part.
    Stillborn's Avatar
    May 2011
    tri-state
    48
    776
    thanks, it's still covered, i just wanted to make sure that it was something i couldn't tackle myself before
    i let the stealership get their grimey paws on it. mucho gracias.
  5. #4
    mrichards is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V
    Sep 2009
    South Texas
    13
    My vented seats worked, but heated portion would not....dealer ended up hosing the bluetooth antenna in the process of fixing the seats. Ended up being the seat controller. Took Chumpion...er um Champion Cadillac a week to get the part and program it properly. So before you leave, check everything out!!!
  6. #5
    Mar 2010
    Detroit, USA
    12,710
    Stillborn, I'm sorry to hear about your frustrations! I'm not a technician, but if you still have lingering concerns after taking it to a dealership for service I'm always happy to assist. (And if you don't have a dealership you regularly use, I'm happy to help locate one on your behalf.) Please keep us posted on your progress!
    mrichards, I can completely appreciate your frustration in that instance and appreciate you sharing that with us. Sorry you experienced that with your V! Is everything alright with your Bluetooth and heated seats now?
    Best,
    Katie
    Cadillac Customer Service
  • You may not post replies
