Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 77
Thread: no ambient lighting in footwells because...
  1. #16
    gonfishin is offline Cadillac Owners Connoisseur
    Dec 2007
    4,150
    Re: no ambient lighting in footwells because...
    I would like to thank RAB for researching and posting his installation instructions and pics. Here is his info on the REAR ambient lights
    http://www.cadillacforums.com/forums...ight-rear.html
    I have the interior ambient lighting listed on my window sticker.
    So either that refers to the sensor or they did not install lights on my 09 CTS-V
    I have read where that was discontinued on the V. Will clarify Monday with Dealer
    However, I found only the connectors and no lights
    This is what it should look like (driver side) installed
    For those interested in ordering or pressing the dealer for free remedy,
    you should request Front PN 19170639, Rear PN 19170640
    RAB suggested that you check for voltage even if you have the connectors
    Note: the rears require alot of work. Check RAB's installation instructions in above thread
    before ordering to determine if you feel the result is worth the labor
    Also, if you order they can be ordered through gmpartsdirect.com for less than dealer.
    Thanks again RAB for posts (and giving me something else to sweat)
  2. #17
    tbss08's Avatar
    tbss08 is offline Cadillac Owners Fanatic
    Automobile(s): NONE!!!!
    Jan 2009
    Warrick County, IN
    327
    What month was your build date? Just curious when GM stopped the lighting.
  3. #18
    Dec 2007
    4,150
    04/09
    I would appreciate others posting their CTS-V build date and whether they have the lights or not.
  4. #19
    ecorpuz12 is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V, White Diamond, Auto, all optons, Corsa Pipes
    Dec 2007
    Anderson Creek, NC
    186
    04/09....makes me scratch my head that GM would try to save about 38 bucks by not including these in newer builds. cblove...if you happen to test your connector with a voltmeter, please let all of us know your results.
  5. #20
    6DN69's Avatar
    6DN69 is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Coupe
    Jul 2004
    Waldorf, Maryland
    57
    59
    Thanks for the photos cbloveday...
    I'm missing the connector (in the red circle) so I can't add the lights.
  6. #21
    tbss08's Avatar
    Jan 2009
    Warrick County, IN
    327
    Quote Originally Posted by ecorpuz12 View Post
    Actually when you figure in the cost of the circuit, wiring and the light it might be a bit more per car. Add that up over the model run and it could be a good chunk of change. If I had a choice I would want the lighting it adds a little more class to the car.
  7. #22
    4gear70's Avatar
    4gear70 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V (MG9)
    Apr 2007
    B.C. - Canada
    280
    I have the interior 'ambient' lighting in my V (built 03/09) and my window sales/options sticker that I looked up calls it - INTERIOR ACCENT LIGHTING.
  8. #23
    Dec 2007
    4,150
    Quote Originally Posted by 4gear70 View Post
    HMMM, Interesting.
    Do you also have the recaros?
    I will post back within an hour on if I have juice to my connectors.
    04/09 build date
    connection but no lights
    recaros
  9. #24
    Dec 2007
    4,150
    Quote Originally Posted by cbloveday View Post
    04/09
    Edit: Also include window sticker option for interior lighting, whether you have connectors and if you have recaros.
  10. #25
    tbss08's Avatar
    Jan 2009
    Warrick County, IN
    327
    03/09 build date with accent lighting on window sticker. Recaro's with ambient lighting in both the front and back.
  11. #26
    Dec 2007
    4,150
    I just checked for current with a voltage meter and the connector has power. I will buy the front ambient lights tomorrow
  12. #27
    Dec 2007
    Anderson Creek, NC
    186
    that's good news, i guess i'll be ordering mine tomorrow too. i think i'll skip the rear footwells though, sounds like too much work and i don't care to remove all the paneling to access the wires. thanks for checking and posting the results cblove.
    looks like cars built after 03/09 are SOL...what a difference a month makes.
  13. #28
    Dec 2007
    4,150
    Eecorpuz,
    My pleasure. I found out about this irregularity by reading the post put up by RAB and others. They did the legwork.
    I just wanted to share my case and hopefully help others out.
  14. #29
    GMX322V S/C's Avatar
    GMX322V S/C is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V, 2009 535i
    Dec 2008
    SoCal
    1,840
    Quote Originally Posted by tbss08 View Post
    Mind posting a picture of your rear ambient lighting? I have front but not rear footwell ambient lighting. My build date is 10/08, with Recaros.
  15. #30
    dvandentop's Avatar
    dvandentop is offline Cadillac Owners Connoisseur
    Automobile(s): 09 Silver V 06 Silver Z06
    Jul 2005
    Sioux Falls SD
    35
    1,918
    maybe someone can post up the serivce manuals like the guy did for the previous series, even though it was somewhat of a secret to get access
  • You may not post replies
