Originally Posted by Zymurgy There have been some interesting threads going over in the CorvetteForum about GM voiding warranties if there has been a tune performed on the car. Supposedly, GM has a way to tell even if the tune is then replaced with the original factory tune. They can also tell if the ECM/PCM has been replaced. |
There is always an interesting debate raging on the corvetteforum about GM arbitrarily voiding warrties because of mods. This is absolutely not the case! The Magnuson-Moss Warranty Act (US Code - Title 15, Chapter 50, Sections 2301-2312) specifically states that a "warrantor" (in this case - GM) cannot "void" any part of a warranty unless they can
prove that the modification caused the damage. Here's the applicable paragraph:
(c) Waiver of standards
The performance of the duties under subsection (a) of this section shall not be required of the warrantor if he can show that the defect, malfunction, or failure of any warranted consumer product to conform with a written warranty, was caused by damage (not resulting from defect or malfunction) while in the possession of the consumer, or unreasonable use (including failure to provide reasonable and necessary maintenance).
So, as an example, if your transmission fails, GM cannot void the warranty simply because you installed an aftermarket exhaust system...unless they can prove that the exhaust system caused the transmission failure.
