Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Some sunroof help please?
Old 11-08-09, 10:52 AM
tr's-cts's Avatar
Cadillac(s): 2009 cts
View tr's-cts's Photo Album
Casino Cash: $710
I was going to try and adjust my sunroof since the dealers told me basically I'm nuts! After looking at the screws, I don't have the proper "star / allan" head wrench and I'll assume the screw is metric, which I lack those tools in the lower sizes.
Anyway, I recall years ago a service manager told me that if you can pull a dollar bill through the window and seal...it needs to be tightened. Well, not only can I pull it, I can push it...slide it from drivers side to 1/2 way to passenger side. To me too much play.
My question...those of you with sunroof and no wind noise....can you slide a bill between seal and window...and is it tight / snug or very loose.
(I notice just looking at it it seems a little cocked and when you close the door the roof somewhat "puffs" up)
Thanks in advance!
  #2 (permalink)
Old 11-09-09, 06:40 PM
Cadillac(s): Cadillac DI CTS4 Crystal Red
View redvett94's Photo Album
Casino Cash: $10320
Re: Some sunroof help please?
First of all your dealers sucks because its been a known issue on the 08's air leaks. The screw is a torx not an Allen bit and on my CTS4 i cannot pull a bill through the seal.
  #3 (permalink)
Old 11-09-09, 07:40 PM
Cadillac(s): Cadillac CTS4 V6 DI Performance Package, Lt. Platinum/Ebony
View 2laidback's Photo Album
Casino Cash: $4215
Thanks in advance!
There is a Bulletin out on this problem. They replaced mine with a new style center support and front and back seals. Took about an hour labor.
  #4 (permalink)
Old 11-09-09, 07:47 PM
Casino Cash: $4215
I didn't realize your the same guy I gave an answer to 10 days ago. Why don't you stop screwing around and take it to a different dealer? You are under warranty!
  #5 (permalink)
Old 11-09-09, 11:45 PM
Cadillac(s): 2008 CTS/DFI
View MichiganMan's Photo Album
Casino Cash: $275
Do you have the bulletin number? Our dealer has messed with ours off and on at least 3 times. Gets a bit better, then back to Hurricane Katrina outside the glass. I'd love to get it fixed as the warranty is about up and we're thinking of buying after the lease is up (Mama loves her CTS!)
  #6 (permalink)
Old 11-10-09, 11:51 AM
Casino Cash: $4215
I'll give you what's on my service order. This is for a 2008 Don't know if any of this is the Bulletin Number. Service told me there was a bulletin and here are the parts.
61CDZ Exterior Trim 527 WS1
1 15936285 Gutter
2 25852811 Seal
Replace the sunroof front & rear seals (roof seals faulty) With new style center support.
Their comment was "There should be no noise" Got no grief from service dept. Good Luck!
  #7 (permalink)
Old 11-10-09, 05:38 PM
Casino Cash: $10320
Michigan man,
Do you have almost 100K on your car? Because you have a 4yr 100k bumper to bumper warranty. Check out your owners manual.
  #8 (permalink)
Old 11-11-09, 06:18 PM
tr's-cts's Avatar
Casino Cash: $710
I agree with you 100 %. I've had the car into my local dealer 2 X for the same thing. No avail....it's wind turbulance!
The dealer that I purchased it from is 200 miles away. They told me the same thing....I am making an appointment for it next Friday! and telling them to FIX it!
By the way it is an '09.
I get tired of telling these dealers that there is a problem and they treat you as if you never driven a car before. Or they always have some febil excuse. What happened to customer satisfaction.
  #9 (permalink)
Old 11-12-09, 01:37 PM
Cadillac(s): CTS
View exm22psu's Photo Album
Casino Cash: $4545
I wonder if this fix also takes care of the squeaking ... styrofoam sound that I have when I hit a bump or go over uneven pavement.
  #10 (permalink)
Old 11-12-09, 06:07 PM
tr's-cts's Avatar
Casino Cash: $710
The only thing I can say is...try to pinpoint the area as you are driving, using your hand if possible...put pressure on the area and see if the noise subsides.
  #11 (permalink)
Old 11-13-09, 03:20 PM
MidLifeinMI's Avatar
Cadillac(s): '08 CTS 3.6DI AWD
View MidLifeinMI's Photo Album
Casino Cash: $6840
Originally Posted by redvett94 View Post
Michigan man,
Bumper to bumper is 4 years, 50K miles. Powertrain and rust-through go out to 100K.
For the OP, where are you in MI? I had the sunroof "whistling" problem and took it back to my dealer (Audette, in W. Bloomfield), and they knew of the bulletin and took care of it on the first trip.
  #12 (permalink)
Old 11-13-09, 10:13 PM
Cadillac(s): 2008 CTS DI
View louiefl99's Photo Album
Casino Cash: $4098
The screws are either Torx T-25 or 8mm socket. I carry a nut driver with the Torx bit in my trunk to adjust this every once in a while. Up until now I didn't know there was a service bulletin, so I'll have to take it in to get fixed.
  #13 (permalink)
Old 11-15-09, 06:12 AM
ejenci's Avatar
Cadillac(s): CTS 4
View ejenci's Photo Album
Casino Cash: $600
Red face Re: Some sunroof help please?
Can you make a photos where are these screws , I have also big wind noise ( above 150 km/h) . Thanks in advance !
  #14 (permalink)
Old 11-16-09, 01:27 PM
Casino Cash: $4098
Don't have a camera handy, but you should be able to see the screws when you open it in the tilt position. With the rear edge up, you should be able to see the screw between the seal and the glass. You don't need to remove it, only loosen it slightly.
  #15 (permalink)
Old 11-16-09, 09:51 PM
MoFex's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 08 White Diamond CTS DI RWD FE2 all options
View MoFex's Photo Album
Casino Cash: $16638
Thanks guys. U have the same issue. Took this to the dealer - no problems found!
This morning when I drove to the airport (70 - 80 mph) there was definitely wind noise. I slight pressure on the middle cross member and the noise was gone! I guess this calls for another trip the the dealer....how many more?.....
sunroof
Censor is OFF
