Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Battery Disconnect
Old 11-06-09, 11:23 AM
Cadillac(s): 09 CTS4
View 09cts4awd's Photo Album
Casino Cash: $335
Battery Disconnect
I was looking at the battery in the trunk yesterday.
Silly question ..
What's the proper procedure to disconnect the negative lead?
There is a black rubber covered lever that looks like its locked into place. I can slide to out to the opening, but it does not release or move up or anything obvious.
I'm used to the older cars with the locking nut to loosen, but don't see a nut on this one.
Is there some special tool you have to use, or am I just not seeing it? I don't want to exert any excessive force and break something, so I just slid it back into locked position.
It's probably very obvious, I'm just being cautious.
Thanks..
09cts4awd
  #2 (permalink)
Old 11-06-09, 06:40 PM
Cadillac Owners Enthusiast
Cadillac(s): Cadillac
View ddawson's Photo Album
Casino Cash: $14415
Re: Battery Disconnect
Leave the battery alone.
  #3 (permalink)
Old 11-06-09, 07:32 PM
Cadillac(s): Cadillac CTS4 V6 DI Performance Package, Lt. Platinum/Ebony
View 2laidback's Photo Album
Casino Cash: $4215
Curiosity killed the cat. Leave it alone and call the dealer when you have a problem.
  #4 (permalink)
Old 11-06-09, 10:51 PM
tr's-cts's Avatar
Cadillac(s): 2009 cts
View tr's-cts's Photo Album
Casino Cash: $710
So I suppose.....We shouldn't disconnect the battery ( like in the old cars) to reset the computor? I know I did this a couple of times with my 300. It solved some of my minor problems.
I have read here that with battery failure on the CTS's that "things" need to be reset? Is there some kind of a list?
  #5 (permalink)
Old 11-07-09, 10:55 AM
Toronto Owner's Avatar
View Toronto Owner's Photo Album
Casino Cash: $1220
Don't open pandora's box
  #6 (permalink)
Old 11-07-09, 11:05 AM
Cadillac(s): Cadillac DI CTS4 Crystal Red
View redvett94's Photo Album
Casino Cash: $10345
Leave it alone and worry about it after 100K if you still have the car. Unhooking the battery Will require you to reset several components. If you have a dead battery sometime call the dealer to pick it up and fix it.
  #7 (permalink)
Old 11-11-09, 09:17 PM
Cadillac(s): 2006 Cadillac CTS 6MT, 2008 Cadillac CTS 6MT
View fritze18's Photo Album
Casino Cash: $4710
09CTS4AWD- While I agree with everyone on here that you should not disconnect your battery for no reason at all; you did ask how to disconnect your battery. This forum is about asking and answering questions and helping others. You did not ask "Should I disconnect my battery?"
So, here's what you do with that black "tab". Lift up and swing it to the right (while lifting it up). When this tab is loosened, you should be able to just slide the connector off the terminal. You should not need to apply excessive force at all. If so, then consult your dealer.
Don't let everyone scare you into not disconnecting your battery if you need to. When/if you do disconnect your battery, be sure to read your owner's manual for instructions how to properly connect your battery and reset everything. It's really not that scary; if it was truly dangerous, the battery would be inaccessible. Just use common sense and follow the owner's manual; it's there for a reason!
  #8 (permalink)
Old 11-12-09, 06:18 PM
tr's-cts's Avatar
Casino Cash: $710
WOW.... Good answer.
I'd hate to be in a situation where the battery went dead and I needed a jump and was afraid to. 'Cause I really don't like tow trucks and there pricing! I always carry jumper cables for me or thee! In fact I thought it was a cool idea to have the battery in the trunk, easier to get and give a jump if need be.
( No, I do not jump everyone...just family if need be. )
  #9 (permalink)
Old 11-12-09, 06:36 PM
Casino Cash: $14415
Sometimes a LITTLE knowledge is DANGEROUS.
  #10 (permalink)
Old 11-13-09, 02:21 PM
Cadillac(s): Cadillac 08CTS Hot Lava 3.6DI RWD special edition
View 08lava's Photo Album
Casino Cash: $7780
There are jump points under the hood.. no need to get into the trunk.
  #11 (permalink)
Old 11-13-09, 02:41 PM
Casino Cash: $10345
If you read the owners manual it states to only jump from the engine compartment. 2008 page 5-45.
  #12 (permalink)
Old 11-13-09, 04:56 PM
Casino Cash: $14415
Close the trunk, close the hood and leave the battery alone.
battery, disconnect
Censor is OFF
