| Re: Will these tires fit? The 255/45 will be slightly smaller in diameter than stock - speedometer error of less than 1%
The 245/45 will be smaller in diameter by about 2%
The 235/40 will be significantly smaller in diameter - about 7%. If your speedometer reads 60mph, you'll actually be going about 56mph.
The section widths are all within about 0.5", so you'll only be modestly wider - should be no problem staying within the wheel wells. All the mentioned tires are also rated for use on 8" wide rims, so again, no problems. |
