Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Do your headlamps look like this?!
  #31 (permalink)
Old 07-13-09, 01:16 PM
PAO PAO is offline
Cadillac(s): 09 CTS 3.6 Metallic Red, 06 Pontiac Solstice, 04 Malibu Maxx
View PAO's Photo Album
Casino Cash: $1696
Re: Do your headlamps look like this?!
Originally Posted by 928S View Post
GM Technical Service Bulletin, posted above by Michael 514, says:
"...Some exterior lamps, such as cornering, turn signal, backup, headlamps or tail lamps may exhibit very small droplets of water, a fine mist or white fog (condensation) on the inside of the lamp lens. This may be more noticeable on lamps with "multi-lens" designs and may be normal during certain weather conditions. Condensation occurs when the air inside the lamp assembly, through atmospheric changes, reaches the "dew point...The condition should clear of moisture when the vehicle is parked in a dry environment, or when the vehicle is driven with the lights ON..."
And, like C6Vette said, we're talking about occasional condensation (not a water leak) on the inside surface of the vented lamp assembly's outer lens (not inside the sealed lightbulb lens).
I'm with GM on this one.
I personally think this is a cop-out on GMs part on this...over time..if it is consistent..which this one appears to be the inside lenses will develop a haze which you cannot reach to clean....this shouldnt happen on a $50K car.....IMHO
headlamps
Censor is OFF
