Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: HID Conversion Kit
Old 03-11-09, 11:31 AM
08CTSAWD's Avatar
Cadillac(s): 2008 CTS AWD
View 08CTSAWD's Photo Album
Casino Cash: $3070
HID Conversion Kit
I have an 08 CTS with the standard projector beam headlights. I'd like to install a HID conversion kit with 10,000K bulbs - is there anything special I should know? I know my current high / low beam bulbs are housed separately in the headlight casing, will this cause an issue with high / low Xenons?
  #2 (permalink)
Old 03-11-09, 01:47 PM
Cadillac(s): Cadillac
View cts2008lover's Photo Album
Casino Cash: $9995
Re: HID Conversion Kit
I think low beam and driving light are using same bulb 11. You may have no driving light with HID Conversion Kit.
  #3 (permalink)
Old 03-11-09, 02:25 PM
08CTSAWD's Avatar
Casino Cash: $3070
so no daytime running light is what you're saying? i think i'm ok with that trade-off...
  #4 (permalink)
Old 03-11-09, 06:23 PM
08CTSAWD's Avatar
Casino Cash: $3070
if anyone has at least replaced their stock halogen bulbs with a HID conversion kit - could you offer some tips, brands, bulb sizes, anything? I'm new to this whole thing...
  #5 (permalink)
Old 03-12-09, 12:55 PM
View Domasac's Photo Album
Casino Cash: $1550
I changed out the factory HID to a better temperature bulb, one thing you need to know is you need to drop the bumper. That is the biggest concern.
  #6 (permalink)
Old 03-12-09, 02:15 PM
08CTSAWD's Avatar
Casino Cash: $3070
oh man, if that's the case just for changing the bulbs, then installing a conversion kit must def require that...
  #7 (permalink)
Old 03-12-09, 04:21 PM
MoFex's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 08 White Diamond CTS DI RWD FE2 all options
View MoFex's Photo Album
Casino Cash: $16663
What do you mean by "better temperature"?
  #8 (permalink)
Old 03-12-09, 04:43 PM
Casino Cash: $1550
factory HIDs are approximately 4,300k degree kelvin, which is a whitish blue tint, I wanted an extreme blue light, mine are upwards of around 30,000k which is a very deep blue, it is not as bright, but I have 20/10 vision and it is still very nice, I just wanted that custom look. These bulbs were engineered to be this blue, generally above 10,000k bulbs tend to look puple, but these are a dark exotic blue.
http://rides.webshots.com/album/564112880HfMKZJ
  #9 (permalink)
Old 03-12-09, 11:48 PM
View Maynor's Photo Album
Casino Cash: $2755
You will have to drop the bumper to be able to remove the headlights from the car and access the rear covers for access to the bulbs. Not real hard to do. Just time consuming.
The one drawback will be your converted HID lights will ALWAYS be on. Unless you pull the fuse for the day time running lights, they day time running light circut will also fire up the HID ballasts during the day. Its a simple fuse pull and problem solved if you want to do it.
  #10 (permalink)
Old 03-12-09, 11:53 PM
Cadillac(s): 2006 Cadillac CTS 6MT, 2008 Cadillac CTS 6MT
View fritze18's Photo Album
Casino Cash: $4710
08CTSAWD- I'm not fully educated on the non-HID systems of our CTS', but by the sounds of things here, the daytime running light is produced by the low-beam headlight, correct? In this case, it's highly unlikely that you will lose your daytime running light. What usually happens is your HID's will flicker instead, causing a very short life-span on your capsules (bulbs). If you enjoy dropping your bumper and throwing away $$$, then this would be the route to take. I have read that you can purchase a relay and some sort of a wiring harness to override the flickering; however, it's my understanding that this kit takes away your daytime running lights completely. In Canada, daytime running lights are required by law. I would do more research on how the system in your specific model operates, and which HID kits are available for your application. Also, verify laws in your state regarding daytime running lights. Hopefully this helps!
  #11 (permalink)
Old 03-13-09, 10:30 AM
08CTSAWD's Avatar
Casino Cash: $3070
yes, I'll def be pulling the fuse on the daytime running lights - thanks for the heads up. Maynor have you installed a HID conversion kit(s) for highs and / or lows? If so, could you point me in the right direction cause i'm having a helluva time getting straight answers out of any vendors.
  #12 (permalink)
Old 03-13-09, 11:31 AM
MoFex's Avatar
Casino Cash: $16663
Oh, you wanted the "rice" look. Now I understand...
You sacrifice the safety for the "look"...
  #13 (permalink)
Old 03-13-09, 11:37 AM
Casino Cash: $9995
In my opinion, It will be much easier if you put HID on low beam headlamp and/or fog Light. Not in High beam.
Low beam headlamp bulb type H11 (OEM 55W)
High beam headlamp bulb type H9 (OEM 65W - No Ballastic)
Fog Light bulb type H11
The H11 bulbs are so popular but I don't know why H11 connectors are so expensive.
Please post how to remove the front bumper, step by step guide. Please....
  #14 (permalink)
Old 03-13-09, 01:15 PM
Casino Cash: $9995
There is an excellent post how to remove 04 CTS-V bumper on V forum.
http://www.jon04ctsv.com/bumper_removal/
It should be helpful
  #15 (permalink)
Old 03-13-09, 02:02 PM
Casino Cash: $9995
55W HID? All around ~$100
http://www.sharphid.com/
http://www.xtremehids.com/product_in...roducts_id=440
Tags: , , , ,
bulbs, conversion, headlights, hid, kit, lights, xenon
Censor is OFF
