| Re: Radio Touch Screen Display Dimmer Mine cycles through all three, but there's not much difference between "auto" and either "day" or "night," depending on the external light conditions. If the car is in a relatively bright area, auto is going to be very much like day; if it's in a relatively dark area, auto will be about the same as night.
The two dim effects you're seeing are actually night and the auto setting for wherever you are, which is apparently in your garage or someplace relatively dark.
You can verify this with the soft touch controls. Press the tone knob and then select display, and then brightness control. You should see a small sample map and three buttons, day, night, and auto. Press each of these and you'll see the differences in the settings. |
