| Re: External Temperature Indicator Error I have had my 2008 CTS for 90 days and I don't remember the ext. temp being off in the beginning, but it is now. A call to the service dept. didn't help, they said make a few turns and it will correct itself. (??) They thought that the sensor would then update itself. Well it hasn't. I hate to have them start tearing everything apart just for that, but I find that I do rely on the temp. indicator. I have had 5 Infinitis and they all worked perfectly.
There are no TSB's for this problem either. One thing about the whole situation is that the computer went out for about an hour a month ago, no radio diplay, no nav...nothing. Then it just came back about 2 hours later, but then afterwards it seems as though the temp. display problem started. Also, it seems like the radio dsplay will show a song and artist for 4,5 or 6 songs after the song has ended, it doesn't update to the artist that is playing. That too seems to be just recent...just since the computer took a dump.
I would like to know if anyone has had the problem and found a solution?
I will take it to the dealership for a new sensor, but every once and a while it might get close to accurate. Yesterday it stayed at 72 degrees for hours, and then gained 15 degrees in a matter of 5 minutes. |
