Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Brake Squeal!
Old 06-30-08, 11:20 AM
jmangia223's Avatar
Cadillac(s): 08 CTS Thunder Gray DI Loaded RWD
View jmangia223's Photo Album
Casino Cash: $950
Question Brake Squeal!
Less than 6K miles just developed a high pitched brake squeal when moderate pressure applied to brakes to stop...very loud. Anyone have similar issue? Any advice? Inspected rotors no obvious signs of scratching or wear.
  #2 (permalink)
Old 06-30-08, 11:26 AM
MoFex's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 08 White Diamond CTS DI RWD FE2 all options
View MoFex's Photo Album
Casino Cash: $16713
Re: Brake Squeal!
Yes, have the same. Took it to the dealer. Apparently they applied something....worked only for a couple of days....it is back now....just do not have time to go back to the dealer....though I do not know what they actually can do short of changing the pads...
  #3 (permalink)
Old 06-30-08, 01:07 PM
Cadillac(s): 2008 CTS, crystal red, ebony
View firedawg911's Photo Album
Casino Cash: $7680
Re: Brake Squeal!
It hasn't happened on my 2008 CTS yet since I only have 1400 miles on it, but I had a similar problem with my 2005 Escalade before I traded it off last month. A mechanic friend of mine suggested that I do a few "hard" stops at about 40 miles per hour to clean the brake rotors. I did as he suggested and it immediately corrected the squeal. Hope this helps.
  #4 (permalink)
Old 06-30-08, 02:17 PM
MoFex's Avatar
Casino Cash: $16713
Re: Brake Squeal!
Thanks, I will try to do it on my way home. It actually make some sense as the heavy braking should clean any deposit on the rotors....
Will report tomorrow on the results.......
  #5 (permalink)
Old 07-01-08, 10:56 AM
jmangia223's Avatar
Casino Cash: $950
Re: Brake Squeal!
Thanks, I will give it a try also and report on results. I have an appointment at the dealership Thursday morning if this doesn't do it I will have the dealer look at it. Will let you guys know what happens. Thanks, this is a great site due to members like yourselves who respond to posts so quickly!
  #6 (permalink)
Old 07-01-08, 11:46 AM
Cadillac(s): CTS DI Fully Loaded, Magnaflow, CAI, F1 Tint, Rosen TVs
View ngiardina's Photo Album
Casino Cash: $11065
Re: Brake Squeal!
You can also try to "bed" the pads.
Burnishing Instructions
Make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
DO NOT DRAG BRAKES!
Allow 15 minutes for brake system to cool down.
After step 4 your new pads are ready for use.
  #7 (permalink)
Old 07-01-08, 01:03 PM
Cadillac(s): 2008 CTS4
View docestes's Photo Album
Casino Cash: $1850
Re: Brake Squeal!
I have had a squeal occurring only at very low speed with very light brake pressure, such as when easing up to a parking curb.
Ihad it inspected by the dealer, and they said there was some "glazing" because the pads were new.
I will try "bedding" the brakes to see if this helps.
  #8 (permalink)
Old 07-01-08, 04:56 PM
Cadillac(s): Cadillac CTS 3.6
View UHATEME's Photo Album
Casino Cash: $2085
Re: Brake Squeal!
Yea, i get this all the time working for mercedes. You guts are just light brakers, soft on the pedal. Just get a few hard stops under your belt and it will take off the glazing. Dealerships really cant do anything about it, just because it's a wear item, warranty won't cover it, at least mercedes.
  #9 (permalink)
Old 07-01-08, 11:14 PM
Cadillac(s): Cadillac CTS 08
View caddyeyes's Photo Album
Casino Cash: $3540
Re: Brake Squeal!
Dealer told me they were putting different pads on the new ones. Took delivery of mine in January. He ordered the pads and replaced them under warranty.
  #10 (permalink)
Old 07-02-08, 12:24 AM
View lewisforjesus's Photo Album
Casino Cash: $4685
Re: Brake Squeal!
That says something good for Cadillac. Always nice to see positives. Thanks for that post.
Lewis
  #11 (permalink)
Old 07-02-08, 01:32 AM
Cadillac(s): '08 CTS
View Black08CTS's Photo Album
Casino Cash: $7445
Re: Brake Squeal!
I must be one of those light brakers. Two hard brakes did the trick. Thanks for posting this question jmangia. I was about ready to take my car to dealer.
  #12 (permalink)
Old 07-03-08, 11:52 PM
jmangia223's Avatar
Casino Cash: $950
Re: Brake Squeal!
Mine went away after a few hard braking excercises. Had it at the dealer today for regular maintenance and they said no problem.
  #13 (permalink)
Old 07-04-08, 05:30 PM
Raj Raj is offline
Cadillac(s): 08 CTS DI RWD
View Raj's Photo Album
Casino Cash: $3900
Re: Brake Squeal!
I had the same issue but mine was getting worse over time. The dealer ended up changing the pads and I believe they resurfaced the rotors.
  #14 (permalink)
Old 07-04-08, 05:49 PM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $20332
Re: Brake Squeal!
The first three tricks to try with squealing brakes:
1)Hard braking for multiple stops in a row.
2)Remove the pads, radius the edges with a file, and do some hard stops.
3)Go to NAPA, get some brake squeal stop stuff in a tube made by Loctite/Balkamp, and follow the directions.
Don't mess with Binky Bear!
  #15 (permalink)
Old 07-04-08, 06:57 PM
Cadillac(s): 08 CTS CRYSTAL RED + CASHMERE DI FE3
View BillM's Photo Album
Casino Cash: $10880
Re: Brake Squeal!
Which brake package do you have? Would be nice if this addresses the brake dust issue also.
Tags: , ,
brake, squeal
Censor is OFF
