2008+ Cadillac CTS General DiscussionDiscuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Navigation Screen not "Auto" Dimming
There is a thread about bugs in the nav, including some day/night issues. Mine will change by itself and go from one state to the other.
The thread talks about a TSB.
Wait...I have it here........well it is not listed on my paper work. It is simply called the upgrade disc.
My dealer had to order it.
It should be in soon.
Search for a thread with "NAV Lotsa Bugs"
The upgrade disc I am talking about is a TSB. It has nothing to do with upgrading the database. It has everything to do with bug fixing.
It is available now.
I thought something was wrong with my autodimming feature for awhile. I'd back the car out of the garage and have to make the screen brighter so I could see it. Then one day, I didn't and gave it another ten seconds or so after the headlights turned off from being on in the garage. No more problem. Just give it 20 seconds or so after your outside ambient lighting has stabilized for it to make the adjustment.
Nav screen illumination is connected to the IP lights. if nav is on auto dim it dims whenever the IP lights dim (based on the ambient light sensor). when the nav screen is dimmed, the brightness is controlled by the IP dimmer. if it's too low just turn up the IP knob. there is also a button to the right under the analog clock that cycles thru three settings. this can also be used to immediately set to bright if lights are dimmed, or vice versa.
rg
