Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Will 16" rims fit on the 2008+?
Old 05-04-08, 07:09 PM
1500cc's Avatar
View 1500cc's Photo Album
Casino Cash: $885
I have a 2004 CTS and am thinking about getting a 2008 or 2009. I have a good set of 16" snow tires on my 2004 and would like to continue to use them if I get a new CTS. But since the smallest tire size on the new CTSs is 17", I wasn't sure if there would be enough clearance to put on 16" rims. Anyone tried this?
  #2 (permalink)
Old 05-04-08, 07:30 PM
da_thrilla's Avatar
Cadillac(s): 05 V6 SRX4 - All options minus UV+; 08 DI CTS4 minus UV,Wood
View da_thrilla's Photo Album
Casino Cash: $6245
Re: Will 16" rims fit on the 2008+?
dont think there would be an issue of clearance since it is a SMALLER rim...however, bolt pattern differences may be an issue...
i think yours are 6 bolts and the new cts is 5...I might be wrong.
  #3 (permalink)
Old 05-04-08, 08:29 PM
RustedElvis's Avatar
Cadillac(s): 08 Light Platinum CTS
View RustedElvis's Photo Album
Casino Cash: $11715
I can't think of anything you can use from the older CTS on the new one, including wheels. It's pretty much a different car.
  #4 (permalink)
Old 05-04-08, 08:30 PM
1500cc's Avatar
Casino Cash: $885
No, mine's 5 bolt ... it's the Vs that are 6 bolt. But it wouldn't matter because I'd be buying new rims anyhow (I used to re-mount the tires every season on the stock rims).
But the clearance issue I'm concerned with is with the brakes. I seem to recall the fronts are the same size as the previous gen but the backs got bigger. Either way, if GM wasn't planning to use 16" rims they might've made the calipers bigger.
  #5 (permalink)
Old 05-05-08, 12:28 AM
stevbo200's Avatar
Cadillac(s): Cadillac cts
View stevbo200's Photo Album
Casino Cash: $4472
they both are five both they have a different bolt pattern the 04 cts is 5 x 115 and the 08 i think is 5 x 112
  #6 (permalink)
Old 05-05-08, 12:33 AM
WhtDmnd04CTS's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2008 Cadillac CTS4, Performance Collection, NAV, AWD
View WhtDmnd04CTS's Photo Album
Casino Cash: $15560
08 is 5x120
  #7 (permalink)
Old 05-05-08, 02:03 AM
Cadillac(s): 2006 Cadillac CTS 6MT, 2008 Cadillac CTS 6MT
View fritze18's Photo Album
Casino Cash: $4685
I don't know the answer to this for sure, but I can offer you my experience. I have the 18" wheels included in the performance package (Canada). I ran 17" snows all winter, and when taking them off recently, I noticed how LITTLE space there was between the brake caliper and the wheel. From what I saw, I don't think there would be a hope in hell of putting a 16" wheel on, but I could be wrong.
Another problem you may consider is the tire diameter size difference between the 2 vehicles. I believe the tire size on the '04's with the 16" pkg is 225/55/16? The '08's come standard with 235/55/17. There is a 5.27% diameter difference between the 2 tire sizes (3% is the recommended maximum). This can lead to speedometer and odometer differences and possible brake failure (from what I am told). For the peace of mind, I would find out what you can get for your old tires, and buy a new set in the proper size. Just my 2 cents. Good luck!
  #8 (permalink)
Old 05-05-08, 03:41 AM
View Pyromaniac's Photo Album
Casino Cash: $2985
16s would look hideous
  #9 (permalink)
Old 05-23-08, 12:47 PM
View russj262's Photo Album
Casino Cash: $625
Hey Fritze18 or anyone else,
On your comment of running 17" in the winter. Do you have the J55 brake package? I would like to run the stock 17's with winter tires but am not sure they will fit with the larger J55 brakes with the Summer tire package.
Thanks,
Russ-J
  #10 (permalink)
Old 07-30-09, 01:40 PM
Cadillac(s): cts
View JERKSTORE's Photo Album
Casino Cash: $710
why would you do that. I wouldn't put 16" on anything.
  #11 (permalink)
Old 08-02-09, 01:36 PM
Casino Cash: $4685
Thanks,
Russ-J
I do not have the J55 brake pkg (thank God, I've read nothing but complaints on this forum about them), so I wouldn't be able to tell you if 17's will fit that pkg. I would imagine that if the rotors are larger (even by 1"), and the calipers remained the same (I know for sure the pads are different, but not sure about the rotors or cailpers) that you would not be able to fit a 17" wheel on it. With the standard brakes on my vehicle, I couldn't even put my finger between the caliper and the inside of the rim, if that gives you any idea of how little room you have to play with. Do your research though; maybe there is no size difference between the standard and J55 brakes, it could just be compounds and materials used? Hope this helps.
  #12 (permalink)
Old 08-02-09, 11:15 PM
Cadillac(s): 09 CTS-V Red/Ebony Recaros w/MF, pol whls, roof, Nav, 6MT
View marktanner's Photo Album
Casino Cash: $6620
The J55 brakes are bigger (13.5", I believe). The calipers are different, too. I doubt 17s would fit, but perhaps your dealer would let you try a swap in their bay. By the way, I never had any problems with my J55 brakes, and their stopping power and feel were notably better than the standard brakes, at least to me. The PS2s probably help, too.
Tags: , , ,
2008, fit, rims, will 16
Censor is OFF
