Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Ticking with acceleration question?
Old 02-29-08, 09:53 AM
Cadillac(s): Cadillac CTS 08
View caddyeyes's Photo Album
Casino Cash: $3540
I have a slight ticking sound that sounds like it is coming from behind the speedometer. It is not very loud but sounds similar to a vibration. It only happens with acceleration. At first I thought it might be the speedometer cable but I think it is outside under the hood. Anyone got an idea of what it might be. I did not have it or I should say notice it until around 1000 miles. It is not a labor knock from poor gas though. It is constant and not a rattle like the labor knocks.
  #2 (permalink)
Old 02-29-08, 09:55 AM
The guy with the "modding problem"
Cadillac(s): 2008 Black Cherry CTS4 DI
View GTPprix's Photo Album
Casino Cash: $4420
Re: Ticking with acceleration question?
Does it do it from about 1200-3000 RPM and is engine speed dependant? If so my car is going to the proving grounds on Tuesday to test a fix for that Do you know your cars build date perchance? If not shoot me a PM wiht your VIN I want to see how close it is to mine.
Chris White
www.GTOShiftLight.com
2006 Spice Red A4 GTO
2008 Malibu 2LT 3.6L
2008 Trailblazer SS AWD
2008 CTS4
2008 CBR600RR
  #3 (permalink)
Old 02-29-08, 09:59 AM
Casino Cash: $3540
Seems to do it around those rpms. It was built Jan 3 2008. Keep me posted. Will send you a Vin if you still need it. Thanks....BTW...Still Love the Car Everyone....
  #4 (permalink)
Old 02-29-08, 10:01 AM
Casino Cash: $4420
Yeah sounds like you've got the same problem, I'll update you with the solution (and hopefully availabilty to dealers) on Tues/Weds of next week Mine is pretty loud, if I listen for it I can hear it over the radio on low volume and HVAC. Without the radio on my God is it annoying!
  #5 (permalink)
Old 02-29-08, 10:15 AM
View parthent's Photo Album
Casino Cash: $1835
I have the exact same issue. At first I thought it may have been the fan in the front defogger, but that was ruled out when I turned the cliate control system off.
I am going to wait a couple of more weeks before I take mine into the dealer to address the rattle in the rear seats, the power window on the passangers side that seems to not want to work every once in a while, the trim on the centre console on the drivers side that seems to be coming apart under the wood trim and this ticking sound. The reason I wanted to wait is to see if anything else comes up so I can get everything addressed all at once.
Thanks to this AWESOME forum I will be able to tell the service department exactly what is wrong with the car, and all they have to do is fix it.
Please keep us up to date on your findings from the dealer regarding this very annoying ticking sound.
Cheers
  #6 (permalink)
Old 02-29-08, 10:32 AM
Casino Cash: $4420
Parthent whats your build date? Just curious
  #7 (permalink)
Old 02-29-08, 10:36 AM
View 72_Fleetwood's Photo Album
Casino Cash: $1420
I wonder if the sound you are hearing is from the DI system? Do you all have the DI engines?
  #8 (permalink)
Old 02-29-08, 11:13 AM
Casino Cash: $1835
Not too sure about the build date. I picked mine up from the dealer December 14, 2007. My VIN ends with 80152230. I don't know if that helps. I'm not too sure how to look up the exact build date as I am in Canada.
It is a DI engine with AWD.
  #9 (permalink)
Old 02-29-08, 04:00 PM
View av00178's Photo Album
Casino Cash: $395
Are you sure its not the ticking of the injectors from the DI. It makes a ticking sound when you give it gas thats why Cadillac sealed the engine compartment so well.
  #10 (permalink)
Old 02-29-08, 04:12 PM
Casino Cash: $1835
No it's not the DI engine. That has an all together different sound which is a thing of beauty. In my search for where this sound is coming from I found out that even the clock on the centre stack makes at ticking sound. But then again I guess it should being analog and all.
  #11 (permalink)
Old 02-29-08, 04:25 PM
Casino Cash: $4420
Technically the sound IS the engine but the way its getting into the cabin IS NOT intended. If you have this problem it sounds like its coming right from the Instrument panel or right behind it
  #12 (permalink)
Old 02-29-08, 11:50 PM
Cadillac(s): 2008 CTS Blue Chip AWD 3.6DI FE2
View sbudaj's Photo Album
Casino Cash: $1535
I had a similar sound. Took it into the dealer and it turned out that a rubber shield around the steering column at the firewall came loose. Once they repositioned and reseated it, all was quiet again. Have them check yours.
  #13 (permalink)
Old 03-01-08, 10:03 AM
Casino Cash: $4420
We did that when the car went back to the plant so they could check it out. Boot was fine so it got escalated to the proving grounds, we'll see tuesday.
  #14 (permalink)
Old 03-01-08, 12:12 PM
View cts2008lover's Photo Album
Casino Cash: $9995
I also have similar sound. It is coming from under the dashboard between engines on driver side I think I can hear only when I accelerate. I went to the dealer and asked to check but they told me that it's from the DI system. I am not happy with that sound. It's like my clock is ticking every 1/20 sec continously. I think my car was build on Jan.
  #15 (permalink)
Old 03-01-08, 03:26 PM
08CTS's Avatar
Cadillac(s): 2008 Cadillac CTS DI/FE2 Blue Chip/Cashmere
View 08CTS's Photo Album
Casino Cash: $1740
I hear some occasional muted ticking, but I'm confident it's from the DI...keep us posted on your noise, and good luck
Tags: , ,
acceleration, question, ticking
Censor is OFF
