Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forums > Cadillac CTS Second Generation Forum - 2008+ > 2008+ Cadillac CTS General Discussion
2008+ Cadillac CTS General Discussion Discuss everything about the 2008 and newer Cadillac CTS that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Recorded Audio DVDs Don't Work
Old 11-22-07, 09:35 AM
PJL PJL is offline
Cadillac(s): 2008 CTS
View PJL's Photo Album
Casino Cash: $15121
I've been attempting to burn audio DVDs (using Windows Vista and DVD+RW media). I've attempted all of the format options that I think are available but none of the discs plays. When inserted into the audio system it attempts to load the disc but gives a "can't read format" type of error. A commercial audio DVD works just fine. Any guidance on this? I'm trying to transfer large numbers of files over to the HDD and this way because I don't have a large enough USB drive to do it conveniently. Thanks for any help.
  #2 (permalink)
Old 11-22-07, 02:28 PM
sube5186's Avatar
Cadillac(s): 2010 SRX AWD
View sube5186's Photo Album
Casino Cash: $1008
Re: Recorded Audio DVDs Don't Work
Thankfully, this one is an easy fix. You should use DVD-R discs. DVD+RW discs are rewriteable. They are always finicky when trying to play them in drives other than the one you burned them in. I think they even warn you of this on the package. Also, your DVD burning software may be set to leave the disc open after you make a burn. A DVD has to be "finalized" after a burn, otherwise it won't play in other DVD drives. If the disc is left open, you can continue to add more data, music, etc. at another burn session. Once it is finalized, you can't add anything else to it. Some DVD burning software is set by default to leave the disc open, thus allowing one to add additional music at a later session. Some software is set by default to finalize the DVD. Now you have to go into the "Options" or "Settings" section of your software and look for this adjustment.
Sube
  #3 (permalink)
Old 11-24-07, 04:29 PM
Cadillac(s): '08 CTS
View rebelduke's Photo Album
Casino Cash: $6500
I copied about 3Gb worth of MP3 files to a Verbatim DVD +R disk using Nero 8.0 and it played just as expected showing folder and file info on the display. However, your term "Audio DVD" may mean something different.
  #4 (permalink)
Old 11-24-07, 09:05 PM
sube5186's Avatar
Casino Cash: $1008
Will it play dual layer DVDs?
Just curious.....will the audio system player dual layer DVDs? These are not the two sided DVDs. Dual layer has twice the storage capacity of regular DVDs, all on the same side.
Sube
  #5 (permalink)
Old 11-25-07, 01:15 PM
Casino Cash: $6500
Sorry, I don't know. My DVD writer does not support dual layer DVD's so I can't test.
  #6 (permalink)
Old 11-26-07, 11:38 AM
Cadillac(s): 2008 CTS & 2005 Corvette
View gm_eng's Photo Album
Casino Cash: $3749
Audio DVD files are .ac3 format. I ripped some tracks from video DVDs using a DVD audio ripper program and saved them to a DVD-RW disk. I've also made back-up copies of audio DVDs using Roxio that play fine on the CTS.
Tags: , , ,
audio, dvds, recorded, work
Censor is OFF
