Originally Posted by CadiJ Hello Everyone!
Ok I was really hoping to deliver the silver bullet fix for the vibration issues so many of us are having with our CTS's between 40 MPH and 70 MPH.
I have been trying to get GM to fix my CTS since I picked it up in late November.
The new PIP that was just released for this issue instructs the dealer to install:
F2143 Carrier Assembly (complete) Rear Differential Replace. From my paperwork the part number looks to be:
20827776
From what I was told the regional cadillac engineer and district service manager were the two people who tended to my car.
Here is what I have to report: It is WORSE
My shudder prior to the new part install was a "slow shudder" starting at 45/50mph. After the part install the shuddeer is now a "fast shudder" starting at 35mph and continues all the way up to at least 80mph as that's the fastest I got the car up to.
I don't understand how on earth the engineers didn't feel this as I felt it within 2 minutes of leaving the dealership.
NOTE: my paperwork states, "Rear axle mount insulators developed by GM engineering to enhance customer satisfaction were installed to ensure optimal performance..."
SO there we have it, the 2008/2009 CTS platform does in fact have a design/engineering/production flaw which contributes to NVH and for me a very noticeable shudder.
Such a shame, the CTS is a beautiful design but just not the car I thought it would be (for me...) |
CadiJ,
Sorry to hear that this correction did not resolve your problem. Too bad. There are several things I would like to mention. Apparently GM must be afraid that they might have to buy your car back as they apparently are trying to mask the issue by the comments on your repair order about this being an enhancement to your car. That is a joke. Sorry to say but they are playing you for a fool. The bulletin which I am listing for you is the same one as before with the addition of the washers used. Unfortunately, you now must live with a decrease in your fuel economy. I question as to whether a GM engineer actually performed this bulletin to your car. It sounds to me like the dealer did this as per GM's request. Did you ever meet this engineer? Did you drive your car with him to confirm the problem?
Another thing that you mention is that the Service Manager shifted your car into neutral when the vibration occurred and it went away. This is interesting as my car continues the drone/vibrate when shifted into neutral. This tells me that my problem is in the driveshaft or rear differential. Your experience would lead me to believe that it is in the engine or transmission.
I think you need to request that this engineer drive the car with you present so you can verify your concern with him. This way you are not wasting your time by having the car returned to you the same way.
I become angry when I hear the current commercials Cadillac has promoting the CTS as a "World Class Car". GM continues to build and sell a defective designed vehicle as "World Class". Perhaps it is a desperate attempt to keep the company afloat while is lurks on the brink of bankruptcy?
Here is the bulletin that was performed on your car.
08-07-30-044A: Phasing Drone, Boom, Moan or Vibration at 80 km/h (50 mph) or 1000-1300 RPM with Torque Converter Clutch (TCC) Engaged (Reprogram TCM and Install Insulator Washers [On Vehicles Built Without Washers]) - (Feb 11, 2009)
Subject:
Models: 2008-2009 Cadillac CTS
with 6L50 Automatic Transmission (RPO MYB)
This bulletin is being revised to update model years and add insulator washers (only for vehicles built without washers). Please discard Corporate Bulletin Number 08-07-30-044 (Section 04 - Driveline/Axle).
Condition
Some customers may comment on a drone, boom, moan or vibration during light acceleration which phases in and out in intensity.
The condition may be most noticeable at about 80 km/h (50 mph), or 1000 - 1300 engine RPM, and occurs over a speed range of 5 to 8 km/h (3 to 5 mph).
Cause
This condition may be caused by the rear axle assembly responding to engine firing frequencies passed through the driveline when the torque converter clutch (TCC) is engaged.
Correction
For All Vehicles -- Calibration Update
This condition can be verified by driving the vehicle to duplicate the concern and using the Tech 2® to turn off the TCC. If the noise stops when the TCC is turned off, the calibration detailed below should help to eliminate the noise or vibration.
Important:
• This calibration may result in decreased fuel economy up to approximately one mpg/kpg. Because of this, the software should not be used in a vehicle without this concern.
• There are two calibration part numbers that are "selectable" for this controller. Read the description to determine the correct calibration for this condition.
• DO NOT replace rear drive axle or propshaft for this concern.
A revised calibration has been developed to correct this condition. Technicians are to reprogram the transmission control module (TCM) using SPS with the latest software available on TIS2WEB. Refer to the Service Programming System (SPS) procedures in SI. As always make sure your Tech 2® is updated with the latest software version.
For Vehicles Built Prior to VIN Breakpoint 90159377 - Install Insulator Washers After Reprogramming
1. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in SI.
2. Place a transmission jack stand under the rear differential assembly.
3. Remove the two front differential mounting bolts
4. Install the rubber insulators (2), GM P/N 20827776, between the rear drive axle and the body
5. Install the rear differential mounting bolt.
Tighten
Tighten the rear differential mounting bolt (1) to 220 N•m(162 lb ft).
6. Remove the transmission jack stand.
7. Remove the support and lower the vehicle.
Parts Information
Part Number Description Qty
20827776 INSULATOR ASM - DIFF CARR 2
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
K9532* Transmission Control Module Transmission Reprogramming with SPS 0.4 hr
Add Install Rubber Insulators in Rear Differential 0.3 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
