Handling optons for 2013 CTS
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Like Tree2Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Handling optons for 2013 CTS in Cadillac CTS Second Generation Forum - 2008-2013; I'm interested in improving the handling of my 2013 CTS Wagon. After driving a loaned ATS, the CTS seems too ...
    Leonard is offline Cadillac Owners Member
    Automobile(s): 2013 CTS Wagon
    Jul 2013
    41
    I'm interested in improving the handling of my 2013 CTS Wagon. After driving a loaned ATS, the CTS seems too soft with body roll and relatively numb steering. What options are available? I'm not interested in lowering.
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,743
    Re: Handling optons for 2013 CTS
    Not much in the way of suspension mods. Coilovers are the only way, period.
    KLX's Avatar
    KLX
    KLX is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Coupe
    May 2013
    45
    106
    Well I know Bc's are available what types are u using? Plus is anyone out there knows if there is a diameter difference between the v version and the 3.6 version of sway bars? Not thread jacking just asking?
    Jul 2013
    41
    What are coilovers and Bc's?
    KLX's Avatar
    KLX
    May 2013
    45
    106
    BC racing a coilover manufacturer. Just Google coilovers.
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    Ok, here is the best info I can give you: Check with D3 Cadillac, they have springs and adjustable sway bars.....Eibach and H&R also make springs, KW makes adjustable coil overs, and there are several other companies as well..... Check White Line's web site, they make poly bushings for the car... But as I was informed, to reduce the body roll, you may have to lower the car, to reduce the sway, better/larger sway bars..... I have the FE2 suspension, my mechanic measured the sway bars, 29. something front and I think 19 in the rear (mm) ....Something else you might try, what tires are on the car? Mine have the Michelin Pilot HXMV. I plan to upgrade..... I also plan to go with coil overs, or lowering springs and bigger sway bars, and bushing change outs as well. Specifically the radius arm bushings.......... How many miles on the car? The problem with the CTS is getting accurate info on the suspension differences.... Apparently, the FE1, FE2, and I believe the FE3 all use the same springs and sway bars. No matter, the suspension is not to my standards. However, I was told by another Forum member to give it to 5K miles to let the springs settle in, and upgrade the tires. God how I miss my G8, then again, I had to fully mod that suspension as well.... BUT, there were aftermarket parts out the whazzo for that car.....I have spoken to BMR in Tampa, FL and beg them to come up with improved suspension parts for the CTS......Hope this helps out.... BTW, do a search, there are a lot of posts dealing with the CTS suspension.....
    Jul 2013
    41
    Read somewhere that the CTS Sport (the one with the 3.6 Turbo) has a sport suspension that includes 20% stiffer springs. It might have other mods as well (can't get much info about this model from web site). Anyway, wondering whether the suspension mods will fit the regular CTS. If so, perhaps a good way to upgrade.
    If suspension modified, does this void the warranty?
    Jun 2012
    588
    Suspension mods only affect the warranty of the parts replaced.... Should not interfere with GM warranty on the rest of the car......I doubt if the 2014 Springs will fit the second generation..... There were some design changes on the suspension of the 3rd Generation..... This included using lighter weight suspension parts.... Though it would be interesting to see if those springs would fit.... I would rather have stiffer springs but same ride height.... This is how the Pedders Street II suspension worked on the G8.....
    Jul 2013
    41
    Somewhere in the distant past, I remember reading about plugs that could be placed in between the coils to make the springs stiffer. Does this work? If so, pretty cheap and easy.
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,448
    Quote Originally Posted by Leonard View Post
    NO they don't work and you wouldn't like the result if they did work!
    Jul 2013
    41
    Do the V models have a sportier suspension?
    tinman's Avatar
    Jul 2006
    9,743
    Absolutely. However, the V suspension cannot be interchanged. Read here: http://http://www.whyhighend.com/magnetic-suspension.html
    Jul 2013
    41
    Does this mean the XTS handles well because it also has the magnetic shocks?
  16. #14
    tinman's Avatar
    Jul 2006
    9,743
    It might. There are lots of other factors involved for handling other than the shocks and dialing in a "sports setting" on the electronics. Weight, balance (front/rear), chassis setup, center of gravity, tires, sway bars, etc.
  17. #15
    wcthunder's Avatar
    wcthunder is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 CTS Coupe 3.6 RWD Perfomance Pkg, TriCoat White Diamond
    Jan 2012
    Philly Suburbs
    912
    Don't get caught up comparing apples to oranges. The ATS I drove as a loaner felt compact and I could easily feel the shorter wheel base, hence "sportier" feel. You're draggin a lot of wagon my friend.
  18. Remove Advertisements
