Handling optons for 2013 CTS - Page 2
Results 16 to 30 of 32
Like Tree2Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Handling optons for 2013 CTS in Cadillac CTS Second Generation Forum - 2008-2013; I thought the ATS was a nice handler....
  1. #16
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,736
    Re: Handling optons for 2013 CTS
  2. #17
    Leonard is offline Cadillac Owners Member
    Automobile(s): 2013 CTS Wagon
    Jul 2013
    41
    Quote Originally Posted by wcthunder View Post
    Don't get caught up comparing apples to oranges. The ATS I drove as a loaner felt compact and I could easily feel the shorter wheel base, hence "sportier" feel. You're draggin a lot of wagon my friend.
    I think a lot of the better handling of the ATS on the one I drove is due to the run-flat tires which have a really low profile (30-35 I think) and accounts for the kart-like steering. By contrast, my CTS steering feels a bit numb, in addition to too much body lean. I'm going to explore ultra-low profile tire replacements (if there are any for my 19" wheels). I would like to get stiffer springs/shocks but without body lowering. There doesn't seem to be any available.
  3. #18
    tinman's Avatar
    Jul 2006
    8,736
    Coilovers.
  4. #19
    wcthunder's Avatar
    wcthunder is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 CTS Coupe 3.6 RWD Perfomance Pkg, TriCoat White Diamond
    Jan 2012
    Philly Suburbs
    847
    Quote Originally Posted by Leonard View Post
    Between the cost and time the for the changes to turn your CTS wagon into an ATS, you might as well trade in. Isn't that what you want? ATS.
  5. #20
    tinman's Avatar
    Jul 2006
    8,736
    Or a V. Otherwise it just isn't going to happen on your Cadillac without a lot of time and money.
    wcthunder likes this.
  6. #21
    wcthunder's Avatar
    Jan 2012
    Philly Suburbs
    847
    Quote Originally Posted by tinman View Post
    He wants a go-Kart tinman, not a Beast!!!
  7. #22
    tinman's Avatar
    Jul 2006
    8,736
    After re-reading, you're right. My bad, no V for you!
  8. #23
    Jul 2013
    41
    ATS would be nice if it had the room of a CTS wagon. I need the room, else why would I buy one.
  9. #24
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    OK ---UPDATE The 2013 CTS-V Sway Bars will fit the 3,6 and 3.0 CTS ..... The CTS -V Sways are 32mm Front and 22mm rear... Versus the current 29mm Front and 19mm rear that we have..... End links should work but new mounting brackets and bushings will be needed. I would go with the White Line and get the poly bushings..... I am also still looking at changing out the OEM tires... Still think they are a part of the problem....... The major issue is lowering springs versus coil overs.....
  10. #25
    wcthunder's Avatar
    Jan 2012
    Philly Suburbs
    847
    My bad...didn't know you needed wagon space...
  11. #26
    jamiejam1's Avatar
    jamiejam1 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS COUPE Performance W/Navi
    May 2014
    Miami 305
    212
    In respect to the ATS I have my Cts Coupe ( Non- V) and My uncle has an ATS (13) He pulled up next to me leaving dinner the other night, and I think that the car (ATS) may sit a bit Lower as well ( by way of being taller) ground clearance is about the same! with that said, its no wonder that there is more body roll in the C… think Lower center of Gravity...
  12. #27
    wcthunder's Avatar
    Jan 2012
    Philly Suburbs
    847
    Quote Originally Posted by jamiejam1 View Post
    That's correct...Lower COG is a solution. When was the last time you seen an Indy car more than a few inches of the ground? This is a reason why I DON'T want to put larger rims on my car (lift my COG). Because that would mean I have to get a smaller ratio tire, which means harder ride.
  13. #28
    jamiejam1's Avatar
    May 2014
    Miami 305
    212
    well Actually I slapped 20's on with 40 series tires, that raised the car up about 1/4 " from oem height, Then added the eibach spring kit which then brought me down to 1/2 in below OEM height. End result is I filled the wheel gap, Got 10.5" w rims with a wide flushed stance, amazing handling and the car loves the setup! I'm thinking that these rims and tires weigh less than the OEM's they seem to weigh a freaking ton! Just my .02
  14. #29
    Jul 2013
    41
    Harder ride but better handling as less sidewall to flex (i think - correct if I'm wrong). I'm thinking of 20 wheels with 35 profiles which would be close to OEM. I drove an ATS with run-flat 35's and it was like driving a go kart but harsh as you say.
    BC Racing has coilovers for 2013 CTS. Do these fit as standard shocks or are modifications required? Will have to contact Cadillac re warranty situation, also if changing wheels and tires.
  15. #30
    tinman's Avatar
    Jul 2006
    8,736
    You are correct about less sidewall giving better handling as a general rule
    Something about bcs racing and their coilovers not being good. We had a discussion about this earlier.
  16. Remove Advertisements
