Cadillac CTS Intake System
Results 1 to 8 of 8
2008-2013 Cadillac CTS Performance Mods Discussion, Cadillac CTS Intake System in Cadillac CTS Second Generation Forum - 2008-2013; D3 Air Intake | 2008-2012 CTS 6 Cyl #5100100: 2008-2011 Cadillac CTS The D3 Air Intake Kit for the CTS ...
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    The D3 Air Intake Kit for the CTS is a complete system that replaces the OEM closed airbox with a high flow K&N Air Filter.
    By replacing the primary air inlet tube with our larger bore high flow aluminum pipe we are now able to allow for the maximum amount of air to flow through the primary air inlet. The result is a gain of 8-10 HP for the 3.6DI CTS. Additionally the higher flow intake kit requires less effort from the vehicle to take in air allowing for the vehicle to use its existing power much more efficiently.
    Includes:
    D3 Aluminum Air Intake Pipe
    D3 1pc Aluminum Heat Shield
    Genuine K&N Air Filter
    Avab. in High Polished Pipe or Black Powder Coated Pipe
    Custom colors avab upon request
    $295 | USD (In stock and ready to ship)
    http://d3groupinc.com/cts-air-intake/
    Thank you,
    Dr. Design
    D3 Cadillac
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    How does it incorporate the MAF that is molded into the stock box on 2012 3.6DI LFX engines?
    Hmmm. Quick edit I see. Still have to change the other date then too
    holdemhigh's Avatar
    holdemhigh is offline Cadillac Owners Member
    Automobile(s): CTS Coupe
    Mar 2013
    29
    Re: Cadillac CTS Intake System
    Am I correct that this is not available and will not work for a 2013 CTS CPE?
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    Unfortunately there is a cut off in 2012. We are working on a solution for the 2012+ model years.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by holdemhigh View Post
    holdemhigh's Avatar
    Mar 2013
    29
    Quote Originally Posted by Dr. Design
    Hello, Unfortunately there is a cut off in 2012. We are working on a solution for the 2012+ model years. Thank you, Dr. Design D3 Cadillac
    thanks! Let me know when D3 has a solution and then sign me up.
    eborunda's Avatar
    eborunda is offline Cadillac Owners Fanatic
    Dec 2011
    123
    Does it incorporate perfectly to the 08CTS DI 3.6 V6 engine ? ( premium pack. Sedan )
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    Yes it does. Sorry for the delay response.
    Let us know if you have any questions.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by eborunda View Post
    Panzer Leader's Avatar
    Panzer Leader is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS 3.6 V6 RWD Performance Sedan
    Jun 2012
    Mandeville, Louisiana
    588
    Solution to the MAF sensor being molded to the OEM Air box is simple.....Cut the OEM MAF at the point it connects to the OEM box. Connect that end to the new D3 CAI. The diameters just need to be compatible with each other. I doubt that the MAFS will know the difference.
  11. Remove Advertisements
