Misfire fix however
Results 1 to 5 of 5
2008-2013 Cadillac CTS Performance Mods Discussion, Misfire fix however in Cadillac CTS Second Generation Forum - 2008-2013; I was getting a misfire once in a while during acceleration it seems problem was getting worse was advise on ...
    allbee1 is offline Cadillac Owners Member
    Automobile(s): 2008 cts sport
    Sep 2013
    48
    14
    Misfire fix however
    I was getting a misfire once in a while during acceleration it seems problem was getting worse was advise on coil pack could be the problem but which one? I decided to change the plugs to start the process of illumination and sure enough that was the issue plugs were pretty worn here is my 2 questions
    1) found one of the plugs soak in oil what does that mean?
    2) The engine runs with a slight vibration it did not have this before really not very noticeable if your in front of engine but when I look under the car I can see both tail pipe vibrating a bit much causing raddle did I screw something up? It does not throw any codes
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Was the oil burnt, Nd on the electrode only. Or was most of the plug covered in used oil?
    If the tail pipes are shaking, there must be a misfire. The CEL isn't on?
    Sep 2013
    48
    14
    Re: Misfire fix however
    oil was mostly on thread but could not be absolutely sure that is was not on the electro also I plan to run for a few days and remove new plug and see what it looks like. What is the CEL?
    Vanman's Avatar
    Vanman is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Dec 2009
    Vancouver B.C.
    32
    I would like to know what the CEL is too. I have a vibration at idle also but once the engine is fully warmed up and after sitting for a half hour or so then started up again the idle is as it should be. It makes me think that it is a temperature sensor or possible injector fault. But I saw this thread and the note of the CEL and thought that I do not know what it is either.
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    512
    CEL is check engine light
  8. Remove Advertisements
