What is the diameter of the exhaust pipe?
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Like Tree4Likes
2008-2013 Cadillac CTS Performance Mods Discussion, What is the diameter of the exhaust pipe? in Cadillac CTS Second Generation Forum - 2008-2013; I'm putting in cutouts. I know, no performance gain, ricey, sounds like crap- heard all those comments from searching. What ...
    arachnyd is offline Cadillac Owners Member
    Automobile(s): CTS
    Sep 2013
    91
    What I didn't find from searching is the exhaust pipe diameter. I'm looking post-cat, pre-muffler. Searching showed the CTS-V is 2.5". Is the non-V (in this case 3.6L DI) also 2.5"?
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    Pretty sure its 2" but love the cutout idea! I wanted to do this but weld a racing muffler/aftermarket one onto the cutout. Kuddos sir upload a vid for me when your done please
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Re: What is the diameter of the exhaust pipe?
    Quote Originally Posted by arachnyd View Post
    Love the idea but you need to get under the car, get dirty, and measure the pipe yourself.
    C "T" ess and Mn800r like this.
    Automobile(s): CTS
    Sep 2013
    91
    Then maybe someone can give me a little bit of insight regarding how to measure the pipe. When a pipe says 2.5", is that OD or ID? Because I measured and came up with ;like 2.3" which is neither 2.5" or 2.0".
    Mar 2012
    Houston TX
    516
    Not that's a good question but the answer is GOOGLE!!! One simple search returned answers to your question. Here is one, with video.
    http://www.onallcylinders.com/2012/0...pipe-diameter/
    I'm watching you for future "I'm too Lazy to type GOOGLE" post". (not really, that would be boring.)
    C "T" ess and Tbbt like this.
    Automobile(s): CTS
    Sep 2013
    91
    I don't know what else you want out of me because google isn't solving my problem.. See, the problem is you have some weird sizes. So while I can measure an OD of about 2.3" diameter, that could be 2 1/4" ID or 2" ID.
    Now I used the string method instead of a tape measure (like I did the first time), and I came up with the dimension of 2 1/8" OD, which would be too small for 2 1/4" ID, which tells me its 2", but I'd still love to see someone else confirm it. Makes me feel better about myself!
    Now that I know its 2" ID and 2 1/8". Can a 2 1/4" compress enough with a hose clamp to slip it over the 2" pipe and clamp it down (Can't weld stainless), or do I need to get a 2" and use flanges?
    In my defense, when you do plumbing, they have OD and ID numbers. Exhaust has a single number. When I do search (Here's one of the first sites that came up: http://www.yotatech.com/f123/how-do-...i-d-o-d-65676/ ) The word on the street is "It depends- usually its ID but sometimes its OD"
    And to defend myself on your fears of me just being too lazy, I've done way more "How-Tos" than most posters on other forums, so trust me when I say in time I'll add more to the forum than I'll ask!
    How to reupholster your top: http://www.slkworld.com/slk-r170-cla...er-solved.html
    How to rebuild convertible top cylinders on convertible hard tops: http://www.slkworld.com/slk-r170-cla...-rebuilds.html
    Car Stereo Installation: http://www.slkworld.com/slk-r170-gen...der-200-a.html
    Install backup camera: http://chevyavalanchefanclub.com/caf...,139521.0.html
    How to install remote tailgate lock: http://chevyavalanchefanclub.com/caf...,139580.0.html
    DIY Window Tint: http://chevyavalanchefanclub.com/caf...39522.new.html
    Determined RPO Codes for Avalanche: http://chevyavalanchefanclub.com/caf...tml#msg2026182
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,622
    Pipe and tube is measured on the outside, hose is on the ID, exceptions to every rule sure but for the most part. The exhaust is made out of tubing not pipe, pipe has odd sizes on the OD that do not match the size of pipe, 2" pipe is 2 3/8 OD
    Pipe has to be the same or you could not thread it or clamp it, tube needs to be the same as well so fittings and clamps work. Hose gets bigger on the outside, pipe and tube on the inside.
    If you get 2.3 I would say it is 2 1/4 (2.25), my SRX was 2 1/4 and 2 1/2 depending on where it was in the system so I can see them using 2 1/4. 2 1/8 would be 2.125 and I really can't see them using it.
    Stainless welds just like carbon steel, weld it up if you can. Or get a shop to make you an expander or reducer to do what you need.
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,718
    Quote Originally Posted by conedoctor View Post
    Pipe and tube is measured on the outside, hose is on the ID, exceptions to every rule sure but for the most part. The exhaust is made out of tubing not pipe, pipe has odd sizes on the OD that do not match the size of pipe, 2" pipe is 2 3/8 OD.
    Tubing is measured on the OD; pipe is measured ID. Hence, 2" schedule 40 IPS measures approximately 2-3/8" outside diameter. 2" tubing, whether it is .060 wall or say .125 wall will still measure 2" OD.
    Stainless welds like carbon, yes, but you should really use stainless rod. This is my everyday business...I am more than willing to help you out with facts and information if you ask. PM if interested.
    Sep 2007
    2,622
    Pipe is measured on the OD as it never changes, just like tube never changes on the OD. I deal with pipe and tube as well, most of the time it is OD and wall thickness and ID does not really enter the picture. Using ID would be a pain IMO
    Yes you should use stainless rod, but if you are a DIYer and have the wire/rod then I say rock on, it may not last as long but the 400 series the exhaust is made out of will rust anyway.
    tinman's Avatar
    Jul 2006
    9,718
    How would you order one length of 2" schedule 40 IPS?
    20' of 2" sch 40
    or
    20' of 2-3/8" sch 40?
    Sep 2007
    2,622
    I order by the size, but the size has little to do with the size.
    So I would order 2" sch 40, 2 3/8 does not exist. When I order pipe or tube for fluid lines I already know the OD and the ID varies on the pressure rating I need but other than flow I don't care what the ID is as I don't thread, clamp, socket, flare or compress the ID. The actual OD of pipe is never mentioned in the ordering process, now if I am looking for a piece or at Metal Supermarket then I need the OD or wall thickness to make sure it is right. If I have to order 2 3/8 OD pipe I have called the wrong guys lol
    When I order tubing for machining it is all OD wall, cold is on size and hot finish is always nominal.
    tinman's Avatar
    Jul 2006
    9,718
    Okay, we're on the same page. But what I did not understand in your post (#9) is you stated "Pipe is measured on the OD as it never changes". That is where you lost me. And that doesn't take much sometimes.
    Sep 2007
    2,622
    LOL, cool.
    My favorite metal thing is how everyone always has to mention "billet aircraft aluminum", nice words for chunk of 6061-T6...
  16. #14
    tinman's Avatar
    Jul 2006
    9,718
    But 6061 T6 is so ordinary. You can charge more for billet aircraft aluminum.
    I used to be in the mechanical insulation business. When we had to use insulating cement on the head of an insulated tank, for instance, we had to reinforce it with chicken wire. Heck, we couldn't tell the customer that. We sold them hexagonal poultry netting.
  17. #15
    Sep 2007
    2,622
    Lol.
  18. Remove Advertisements
