How do factory brake cooling ducts on 2008+ CTS non-v attach to foglamp bezel?
Results 1 to 14 of 14
2008-2013 Cadillac CTS Performance Mods Discussion, How do factory brake cooling ducts on 2008+ CTS non-v attach to foglamp bezel? in Cadillac CTS Second Generation Forum - 2008-2013; I am trying to install factory brake cooling ducts to my non-v CTS Sedan but there is a blocking plate ...
    07cts is offline Cadillac Owners Fanatic
    Automobile(s): 07 cts
    Feb 2009
    100
    I am trying to install factory brake cooling ducts to my non-v CTS Sedan but there is a blocking plate on my foglight bezel. How does the brake duct attach to the bezel. is there an intermediate attaching plate of some kind? Pics would be awesome. Thanks in advance.
    Feb 2009
    100
    Re: How do factory brake cooling ducts on 2008+ CTS non-v attach to foglamp bezel?
    C'mon guys, I know you have had this apart to change bezels and modify for air filter intake. Surely someone knows the p/n or has a pic or something?
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,622
    Go to one of the gm parts sites and pull the drawing, that should give you all the info.
    Feb 2009
    100
    Have already done this! The older schematics show only the bezel and 2 ducts. The newer ones only show the bezel and no ducts. None show the adapter piece
    Quote Originally Posted by conedoctor View Post
    caymincozrio is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Coupe AWD Performance Collection
    Jul 2011
    17
    I pullled off my plastic covers and let the air pass through without the additional tube. Looks more menacing with the opening instead of the stupid gray fake mesh cover.
    CTS_'s Avatar
    CTS_ is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS
    Dec 2013
    23
    Quote Originally Posted by caymincozrio View Post
    Any pictures?
    jimbobucket is offline Cadillac Owners Member
    Automobile(s): 2012 CTS 3.6 AWD Premium
    Feb 2013
    Murrysville, PA
    4
    I don't know if you've figured it out yet or not, but here's the path I'm heading down.
    You'll need a #21 in Left 20772527 & Right 20772528 & 2x #22 15272166
    I don't yet know if they pull from the center of the main grill opening or the faux inlet at my fog light.
    I have them running my vin to see how this is going to plumb in for me.
    rtlawlor is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS 3.6L Direct Injection
    Jun 2014
    Huntington Beach, CA
    31
    22
    they pull the air from the side of the fog light bezel, My model came with them. But i notice on cheaper models the bezel has a plastic cover, or its a single piece with no scare opening for part #21 to attach. It attached with one of those black inserts through the top of fog light bezel through #21. and #21 has a notch to screw it in on the side facing the engine.
    then the air goes through #22 and attached to #4, that has a hole for it
    Feb 2009
    100
    Yep, all installed and look/work perfect. On the newer CTS there was a redesign to the bumper and the tabs that hold the brake duct were removed. Once I discovered this, I realized that I would need to fabricate my own brackets in place of the missing bumper tabs. It was pretty simple really. I attached some small right angle aluminum brackets where the bumper tabs should have been (you can tell the location looking at the inside bumper mold) and then attached the bumper duct to it making sure it lines up evenly around the chrome bezel opening. I used small plastic flathead pushpins through the bumper which get covered by the chrome bezel when it's re-installed so they are never visible, I secured them with nuts on the underside of the bracket to make sure they don't come loose. The rest just snaps together as it should, second duct to first duct and then to inner fender. You won't need the brake opening covers on the chrome bezel or the caps on the inner fender anymore. I picked up all the ducts for $8 on Ebay and they look brand new
    microfuture is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS 3.6 LY7
    Jan 2015
    San Luis Obispo, CA
    239
    ...I've wondered why GM decided to switch from vented to unvented? Think there was a TSB about
    wheel sensor corrosion, maybe that's it? At this point, GM only sells 'unvented' fascia (i.e. fake grill where
    the air intake was) replacement parts, but you can still buy vented fascia from aftermarket supplier.
    Feb 2009
    100
    Quote Originally Posted by microfuture View Post
    I believe that may be the reason for the redesign, funny though, they didn't have to change the bumper mold, as the bezels already incorporate a block-off plate lol.
    You should be able to get the bezels with opening just like the chrome ones on my 2013. The crosshatch blocking plate removes easily leaving the opening for the brake duct...
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,714
    Performance package on mine included the ducting.
    Harley03joe's Avatar
    Harley03joe is offline Cadillac Owners Member
    Automobile(s): 2011 Cadillac CTS Premium
    Aug 2013
    South Florida
    75
    37
    Quote Originally Posted by 07cts View Post
    $8.00 Boy You Got Lucky , Any Pictures Of Your Duct Work ?? I Have A 2011 CTS Premium And It Did Not Come With Duct Work For The Brakes , The Premium Model Was Not The Cheap Model 07 CTS Send Me Pictures To Jjvjjv@aol.com Or Post On Here
    Thank You
    Harley03joe
  16. #14
    Aug 2013
    South Florida
    75
    37
    Here Is The Info You All Want PICTURES PICTURES And Part #'s
    Preliminary Procedure
    Remove the front wheelhouse extension. Refer to Wheelhouse Extension Replacement.
    1 Front Brake Caliper Cooling Duct Rear
    Front Brake Caliper Cooling Duct Retainer (Qty: 2)
    Tip
    Use a suitable tool in order to remove the brake caliper cooling duct retainers.
    3
    Front Brake Caliper Cooling Duct Front
    Tip
    Remove the duct from the bottomside of the windshield washer container assembly.
    Remove the front wheelhouse extension. Refer to Wheelhouse Extension Replacement .
    1
    Tip
    Use a suitable tool in order to remove the brake caliper cooling duct retainers from
    the front side of the bumper fascia.
    2 Front Brake Caliper Cooling Duct Rear
    3
    Tip
    Remove the duct from the front fog lamp bezel assembly.
    These Are The Parts
    Part Number
    Got From >>>www.Gmpartsdirect.com
    15272166 2
    REAR DUCT $30.87 X 2 = $61.74
    20772527 1
    FRONT DUCT $30.87
    20772528 1
    FRONT DUCT $30.87
    Handling $30.00
    Total $153.48
  17. Remove Advertisements
