2010 CTS 3.6 engine oil air vapor catch can install - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
2008-2013 Cadillac CTS Performance Mods Discussion, 2010 CTS 3.6 engine oil air vapor catch can install in Cadillac CTS Second Generation Forum - 2008-2013; Also, Make sure you remove the orfice barb and do the drill mod. All 2013's have the larger holes now ...
  1. #16
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Re: 2010 CTS 3.6 engine oil air vapor catch can install
    Also,
    Make sure you remove the orfice barb and do the drill mod. All 2013's have the larger holes now from the factory.
  2. #17
    Wayne's World is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Coupe
    Apr 2012
    New Jersey
    74
    46
    Mistercoffee2: I would be interested in knowing how you removed the tube. I like to keep my car original so I made a half-hearted attempt at it but I was afraid of breaking something so I gave up. Did you use a heat gun or something & did you damage the tube?
  3. #18
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by Wayne's World View Post
    I removed the hose along with the PCV valve from the valve cover and the fitting from the intake, took it in the house, and yes, heat gunned it. The hose was very hard from years of heat and, as you can see in the photo, one end broke.
    I put the new hose on the PVC Valve and the intake fitting which is a better looking install but functions no better then cutting the hose..
    [/COLOR]
    Quote Originally Posted by SC2150 View Post
    Also,
    I Did not know that! I assume you refer to the orifice pictured here. Problem is the Service Manual does not say where it is located. Where is MOD documented?
  5. #19
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    It is in the rear of the passenger side valve cover where the line from the top of the intake manifold snapped on. Grab it with a plyers at the base, twist and pull up and it pops right out. Then drill to 7/64" both the single top and 2 bottom holes, clean debris and seat back in fully and your good to go.
  6. Remove Advertisements
