oil gauge maxes out and
Results 1 to 3 of 3
2008-2013 Cadillac CTS Performance Mods Discussion, oil gauge maxes out and in Cadillac CTS Second Generation Forum - 2008-2013; Just bought the car with little over 40k miles The oil gauge usually at idle sits around 50 but when ...
    Brandon_zavala95 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac cts
    Aug 2013
    1
    Just bought the car with little over 40k miles The oil gauge usually at idle sits around 50 but when i floor it or am gong up hill it goes all the way up to 80 is this normal i thought it was cause i need an oil change cause it said 12% when i got the car but no change in the way the gauge acts since the oil change. and also if you can help the cars real loud as if the ac fans on or whatever but it never goes off im sure thats not normal any ideas on whats causing it?
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: oil gauge maxes out and
    The noise you are hearing might be coming from the center air vents. There was a fix back in 2008 which called for pulling the vents out and adding something to quiet them down. I don't really remember exactly but it was done to my 2008. Try a search for "a/c vent or dash noise" It may take a little bit of work narrowing down the search but I know it's there.
    As far as your oil gauge, I have nothing to offer.
    Ramv is offline Cadillac Owners Fanatic
    Feb 2013
    117
    Oil gauge sounds normal. I assume they run high oil pressure due to the VVT? Anyway, ours does the same thing.
