Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: 2008 CTS throwing multiple codes, dealer can't find problem
    katamarie69's Avatar
    katamarie69 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS
    Aug 2013
    Fishers, IN
    13
    Just bought this car, all was fine for 3 weeks took it to dealer to have a trim piece put in place correctly and now I'm having crazy issues with the car! I only drove it 3 mikes from dealer and the check engine light came on, service stability came on, ABS light, break light and it has been back 3 times and they can't figure out what is causing this issue. They requested a manager drive my car back and forth to his home for a few days (I prefer not to do this) once on my way back from traveling the car shut itself down.. I've had tons of codes show up but the cadillac dealer can't seem to figure it out! While out of town it went crazy again and another cadillac dealer said they had no clue... If anybody has experienced this and have any answers I would appreciate a response...
    1st time pulled lights from; traction control, service stabilitrac, check engine code; p0700 then 2nd time pulled p0100, p0113, and c0561. They stated that when inspected they didn't hook up the mass air flow sensor.. 3rd time while at an out of town cadillac dealer, they pulled codes p0856, p2544, p0575, u0140, u0121 and u0073. They seriously have no clue what's causing these codes...
    Tbbt is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS4 Premium Wagon-Diamond White-Cashmere Interior
    Aug 2012
    Castle Pines, CO
    73
    2,403
    Re: Cadillac 2008
    Sounds like it's a throttle body issue. I had the exact same lights come on and that was the fix. Replaced the TB and all was OK.
    Good Luck, Marv
    Aug 2012
    Castle Pines, CO
    73
    2,403
    Re: Cts
    Welcome to the forum, but don't double post!
  5. #4
    Aug 2013
    Fishers, IN
    13
    Re: Cts
    Thank you.That was by error because it kept saying try again in 30 seconds... If I could figure out how to delete one, I would!
  6. #5
    Aug 2013
    Fishers, IN
    13
    Re: Cadillac 2008
    Thank you! He said well maybe if we replace the EBCM it might work.. I asked how much that would cost and it averaged 1,300 - 1,500. I have the power train warranty, but I really don't know much about a
    vehicle when it comes to that kind-of stuff. Thank you I will suggest this to the dealership in the morning.
  7. #6
    Aug 2012
    Castle Pines, CO
    73
    2,403
    Re: Cadillac 2008
    Good Luck!
    The throttle body is about a $400 repair (just FYI), mine was replaced under warranty, so I don't know the 'real' price.
    Make sure you let us know the outcome.
    Marv
  8. #7
    Aug 2013
    Fishers, IN
    13
    Re: Cadillac 2008
    Thanks for the info, I will post the outcome once it's found... Hopefully if anyone else is having this issue it may help them thanks again!
  9. #8
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    Re: Cts
    It actually sounds like the ECM to me. Computers can do crazy things. If nothing else, tell them to put the trim piece back the way it was maybe the problem will go away.
  10. #9
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,769
    Re: Cts
    Check to see if there are any ground wires in the vacinity of the trim piece they played with. A loose or poor ground can cause problems like you're describing.
  11. #10
    Aug 2013
    Fishers, IN
    13
    Thank you, I just called the cadillac dealer and told them to check the piece.. He stated there is an airbag in that location (the trim piece which runs vertical with the windshield) I'm not sure if he believes this could cause the issue but stated he would have the technician check. He said they plugged in the tech 2 scanner and all lights went off. On my way to the dealer this morning the car seemed like it didn't want to go anywhere. It died on me once and I was finally able to get it started again, of course with a dashboard of warning lights... It only has 60,000 miles on it, I wouldn't think it could have any serious issues. Thanks for your response! I appreciate it!
  12. #11
    Aug 2012
    Castle Pines, CO
    73
    2,403
    Re: Cts
    Was there a warning light that said reduced power? Maybe even a bell sounding?
    Marv
  13. #12
    Aug 2013
    Fishers, IN
    13
    Re: Cts
    There was not a warning light of reduced power, there was a bell sounding noise (loud noise) and I heard a ticking noise coming from the shift location as well (first time I had heard that)
  14. #13
    Aug 2013
    Fishers, IN
    13
    Re: Cts
    I took a photo of the dashboard this morning to show the mechanic. image (9).jpeg
  15. #14
    Aug 2013
    Fishers, IN
    13
    Re: Cts
    The update today is... Still can't locate the problem (this is at a cadillac dealer) they state they won't give
    Up... 10 hours of diagnosing yet can't locate why.. He stated the same thing happened twice to them while test driving however scanning the system comes up with zero problems... They are clueless at this point.. I'm just frustrated!
  16. #15
    Aug 2012
    Castle Pines, CO
    73
    2,403
    Re: Cts
    katamarie,
    Are they providing you with a loner? If so, let them have your car until they correctly diagnose it and repair it.
    I know it's very frustrating! Don't give up!
    Marv
  • You may not post replies
