Cold air intake for 2012 CTS coupe?
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Like Tree4Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Cold air intake for 2012 CTS coupe? in Cadillac CTS Second Generation Forum - 2008-2013; Has anyone come across a 2012 compatible CAI? Most seem to fit up to 2011....
    jprestridge is offline Cadillac Owners Member
    May 2013
    KLX's Avatar
    KLX
    KLX is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Coupe
    May 2013
    45
    106
    I have a 2013 and word is the CTS v's and the 3.6 cts's have the same intake so how would it benefit our cars to put on a cai? Other than looks and sound? Maybe a HP or 2?
    D VADER's Avatar
    D VADER is offline Cadillac Owners Member
    Automobile(s): 2013 CTS Sport Wagon
    Feb 2013
    Central Ohio
    71
    Re: Cold air intake for 2012 CTS coupe?
    I would like to install a Volant CAI but none is listed for the 2013 CTS. I had one on my 2008 CTS and loved it. Seems that both are 3.6 engines so what's the problem?
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    Quote Originally Posted by D VADER View Post
    The design of the stock intake tube has changed. The maf sensor is molded in to the current tube. On most cars, the maf sensor has its own little 1 or two inch section of tube that you unbolt and unclamp from the box and tub and reuse on the CAI. So it just seems like no company has really put in the r&d and time to make one that accommodates the new designed maf sensor.
    Open your hood and check, but I think that's why. On our models the box and tube are one piece
    D VADER likes this.
    D VADER's Avatar
    Feb 2013
    Central Ohio
    71
    Quote Originally Posted by arw1510 View Post
    Maybe the answer is remove the silence baffle and add a K&N Performance filter?
    Oct 2008
    1,229
    Well what are you trying to gain from a CAI? Its only going to be better than the stock one when you are at WOT. Stock filter and stock box will flow more than enough air that the engine needs under normal operating conditions. If you want the different sound then sure, take off the resonator and see if you like it. Performance wise there won't be any difference except at WOT. Most people 'think' that there is gains from installing one, but they just think that because you're going to end up putting your foot down a little harder to hear the better sound that we all love.
    Tbbt likes this.
    wadesemaj is offline Cadillac Owners Member
    Automobile(s): 2011 cts coupe 3.6
    Jan 2013
    12
    The difference is that they went from the 3.6 llt to the 3.6 lfx engine. They are two totally different engine s
    Oct 2008
    1,229
    Quote Originally Posted by wadesemaj View Post
    No. This is true but is not why the cai doesn't work. Its because of the design change of the stock intake like I explained above. But the design change did happen to occur with the usage of the lfx engine. Remember that in 08 they had a direct injected engine also. What changed with the lfx was mainly the use of a plastic intake manifold instead of an aluminum one to save weight and heat transfer.
    D VADER likes this.
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    54
    3,350
    More than that. There was a redesigned front engine cover and then exhaust manifolds are integrated into the heads.
    CTSCHICK Guest
    The main fitment issue with the Volant is going to be the inclosed molded air box if the 12 & 13's are anything like the 2010 & 2011's that have the cars PCM behind the drivers side headlight and underneath the factory air box.
    The Volant box is to big and sits on the pcm and that prevents it from mounting where it has to be mounted.
    The air box on my Volant 08-09 Kit had to be cut & notched on the bottom for clearance because of that and is currently waiting for my b.f.'s friend to plastic weld it so that the PCM is not inside of the bottom of the box.
    So 3 entirely different Volant kits would be needed for the 2nd gen CTS 08-09, 10-11 & 12-13
    Nitro LX is offline Cadillac Owners Member
    Automobile(s): Cts Coupe.
    Aug 2013
    8
    So has anyone found a CAI for the 13 coupe? ive been looking and can only find it for the V.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    I went with the removal of the silencer and have had a K&N filter since the car was new. The change has given me the sound I enjoy and matches what you would expect from such a fast looking car. I did this solely for the sound ,as the ecm will always adjust to the changes in air flow and pretty much negate what ever slight increase you might think you feel.
    Aug 2013
    8
    Quote Originally Posted by C "T" ess View Post
    Sounds like a good idea. Ill try it for now. Hope its not to hard.. kinda new at this ha. i just want it to sound badass right now haha till i can invest some more into it.
  16. #14
    Ramv is offline Cadillac Owners Fanatic
    Feb 2013
    117
    ECM won't restrict air, just give fuel to match if there is a change in restrictions In other words if the intake was a restriction the ECM would help make more power with the removal of restrictions unlike a carb which would be leaned out.
  17. #15
    gohawks63's Avatar
    Feb 2008
    54
    3,350
    Quote Originally Posted by Ramv
    How can it physically remove restrictions? The ECM will adjust the air/fuel ratio depending on air temp, engine temp and power needs
  18. Remove Advertisements
