Ceramic Brakes for Heavy Duty Brakes?
Results 1 to 9 of 9
2008-2013 Cadillac CTS Performance Mods Discussion, Ceramic Brakes for Heavy Duty Brakes? in Cadillac CTS Second Generation Forum - 2008-2013; I have had my 2012 3.6 coupe (performance package) for several months now. Absolutely love the car . However, the ...
    vegaspanton's Avatar
    vegaspanton is offline Cadillac Owners Member
    Automobile(s): 2012 CTS coupe
    Dec 2012
    Las Vegas NV
    12
    I have had my 2012 3.6 coupe (performance package) for several months now. Absolutely love the car. However, the front wheels get very dirty in a short period of time from the heavy duty factory brake pads. I had a similar problem with my C6 with Z51 option and solved it with some quality ceramic brake pads. The CTS coupe is a daily driver. I can not find anyone that makes ceramic pads for the heavy duty brakes on the 3.6 CTS. (Auto Zone, Pep Boys, O Reilly's, Tire Rack, etc.) They all sell a semi metallic pad only for the heavy duty brake option. However, the ceramic brake pads are available for the standard brake package from several of the various manufacturers. Since it appears that no one makes ceramic brakes for the heavy duty brakes, is there a semi metallic pad that does not dust as bad as the factory pads?
    Bandit1's Avatar
    Bandit1 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 3.6 RWD Premium
    Oct 2008
    Ashburn, VA
    497
    Re: Ceramic Brakes for Heavy Duty Brakes?
    Have you checked with Carbotech?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    ACDelco makes ceramic pads too (usually)
    being a perf. pkg. maybe not but it's worth checking
    http://parts-catalog.acdelco.com
    use your VIN instead of picking the car for best results and ease of use
    Dec 2012
    Las Vegas NV
    12
    Put in the VIN and it lists the semi metallic brakes only for the J55 option. It seems like Pep Boys may have a ceramic brake in their PRO STOP series, PR1331C. However, it lists for the 2011 but not the 2012. I think the J55 brake option is the same for both years???? The research continues.
    RAB's Avatar
    RAB
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    Vegaspanton, for your 2012 CTS Coupe equipped with J55 performance (heavy duty) brakes... to greatly reduce visible brake dust on the front wheels you need model "1331" ceramic brake pads. Model 1331 ceramic brake pads are available from several sources, including Pep Boys (PROSTOP PR1331C), Amazon, NAPA and TireRack. All 2nd gen CTS J55 brakes have the same application/dimensions, beginning from the '08 model-year Sport Sedan through to the '13 model-year Sport Sedan and Coupe.
    As info, the matter of replacing the factory semi-metallic front pads with ceramic pads on J55-equipped cars has been covered in several threads over the past 5+ years. Here are links to some of those threads:
    http://www.cadillacforums.com/forums...rd-brakes.html
    http://www.cadillacforums.com/forums...rake-pads.html
    http://www.cadillacforums.com/forums...dont-make.html
    http://www.cadillacforums.com/forums...cts-coupe.html
    Dec 2012
    Las Vegas NV
    12
    Despite not being listed for the 2012 model year, I purchased the ceramic brakes at Pep Boys. It was listed in the 2011 model year with heavy duty brakes. Easy install and good performance with very little brake dust.
    Wag-O-Neer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-4 Wagon Premium 3.6 w/FE2
    Dec 2011
    Maryland
    214
    Quote Originally Posted by vegaspanton View Post
    I second this. I purchased the dustless ceramic pads for my 2010 with the J55 HD brakes. Quite honestly, the easiest brake job I've done.
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    J55.
    That's interesting GM uses the same RPO for my 89 Corvette as they do a 2012 CTS to signify 'heavy duty brakes'
    Sep 2007
    Wilmington, NC
    13,986
    J55 has been used for HD brakes across many car lines and many years/decades
    some RPOs are set in stone - kinda - like this one and the FEx suspension RPOs
    there are some RPO codes that mean different things depending on the year
    but for the most part an RPO usually only means one thing
  12. Remove Advertisements
