Results 1 to 2 of 2
Thread: Eibach issue
    Kenny9123 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Coupe
    Nov 2011
    30
    66
    Eibach issue
    Had lowering springs installed. Fully expected ride to change. But now I notice a 'chatter' in the front when going over bumps. As if something is loose?! I've been under the car. And looked over everything. It all seems good.. Anyone have similar issues?
    btlfedcts is offline Cadillac Owners Member
    Automobile(s): 2010 CTS Sedan, 2012 CTS Coupe, 2015 ATS Coupe
    Jul 2011
    California, USA
    70
    Re: Eibach issue
    Have nearly the exact car and did the install myself. No issues or noise following my DIY guide: http://www.cadillacforums.com/forums...gs-eibach.html
    Did you have the parts installed or do the work yourself?
    The front springs should have been equipped with a rubber isolator on the 2nd and 3rd coil which should prevent any such noises. I would also turn the wheel full left and right and see if the spring is correctly lined up in the upper and lower perches. Both can be moved and will effect ride height and may effect spring bind or noise.
  • You may not post replies
