Volant cold air intake kit for 3.6 Who has one???
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Like Tree2Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Volant cold air intake kit for 3.6 Who has one??? in Cadillac CTS Second Generation Forum - 2008-2013; Modding time The search function only shows a couple results and some of the info is scattered in different threads ...
    CTSCHICK Guest
    Modding time
    The search function only shows a couple results and some of the info is scattered in different threads so I am asking my questions in here..
    This is the kit my b.f. specifically picked out..
    Looking for some input and opinions if you own the Volant Cold air intake kit for 08-11 3.6 http://www.volant.com/edetail.asp?ID=731
    Looking for fitment and quality opinions of this specific kit due to it having a Air duct that actually draws air from out side of the car..
    And I see it has an option for a 2nd duct that can be attached to it..
    The install directions are not available anywhere online and all Volant has posted is the Parts sheet for the kit
    The website says it is only for 08-09 CTS models but I have to assume it is also for 10 & 11"s??
    From what I could gather using the search function and spaced out through different thread no specific to that kit is the duct included ends up behind the grill correct??
    Any one have the 2nd duct hooked up to their kit??
    I have the abilities here to be able to read and document my CTS's pcm to confirm whether the single duct is sufficient enough or not
    Any other information on install, quality of the kit and ect.. would be appreciated before I buy it shortly because it is on sale for $244 and that is a lot cheaper than every one else selling it..
    I Already have experience with the Donaldson designed dry flow air filters so I am not worried about that part of the kit..
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    I have it in my '08 CTS4, and I hate it. Filter isn't secured in the air box at all. The "scoop" is a pain in the ass to install. Get a D3 intake... If I hadn't spent several hundred dollars on this one already, I would buy a D3.
    PTong88 likes this.
    X E Ryder's Avatar
    X E Ryder is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Coupe, Premium, Touring
    Mar 2012
    Northern California
    48
    98
    Re: Volant cold air intake kit for 3.6 Who has one???
    Quote Originally Posted by Michael_atDell View Post
    Bummer. I thought Volant was high on the food chain.
    I did my own mod (found in the 2012+ perf thread) because our airboxes are also used on the 6.2 V - they flow enough with mod.
    Might look at the Airaid also, they have a good product.
    CTSCHICK Guest
    Quote Originally Posted by X E Ryder View Post
    Yeh I saw your modified air box on here my b.f. did something similar on my G5 GT the difference was around 15 degree's while stopped and idling in the summer time
    Not worried about the difficulty with the scoop but could you explain the problem in better detail about the Air filter not securing to the box please??
    ajazolino's Avatar
    ajazolino is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS
    Jul 2010
    32
    236
    I have the volant on my 09, so I can explain, the filter goes into the air box on the left, but it doesn't fit securely into the air box, meaning if you try, you can move the filter around. Nothing major though, it's not going to come out. Another side note, after driving the car hard, I opened the hood and felt the air box, and it was literally freezing to the touch, and everything else was hot. So it does it's job well.
    CTSCHICK Guest
    Quote Originally Posted by ajazolino View Post
    The filter doesnt have a clamp to hold it in place? or is it just some sort of slip fit with no clamp?
    The parts sheet on their site is very vague
    May 2011
    Austin, TX
    37
    404
    I had a Volant on my Vette and loved it, that's why I bought another one. I think the design is poor.
    CTSCHICK Guest
    What exactly is poor with the design??
    I can get the kit new right now on sale for $244 I dunno how long the sale will last..
    May 2011
    Austin, TX
    37
    404
    I don't like the way the filter and air box don't attach...
    Where do you live? If you are close, I'll give you my Volant for for stock...
    CTSCHICK Guest
    Ah so it is slip fit and the filter slides through the box then the rest of the intake kit attache's to it??
    No where close to Texas I am in New Jersey..
    I get it now the maf bolts to an adapter and the filter has an adapter that clamps on the out side of the air box that joins the 2 together..
    With some play in the cut out of the box??
    I can make this work we got 3m weather stripping with double sided tape.. We can wrap the part of the adapter that slides through the box with it making a tighter and better sealing fit
    May 2011
    Austin, TX
    37
    404
    No, the filter doesn't attach to the box at all. You just slip it in there with gaps all around it to suck hot air from your engine compartment into your intake.
    Jagillac's Avatar
    Jagillac is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe
    Oct 2011
    29
    281
    Do you have any photos or could you take some.
    It would make it very clear as to how much of a gap etc.
    Thanks
    loosend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DI RWD w/ Prem & Perf Pkgs Blk/Blk FE2
    Nov 2009
    Maryland
    132
    CoolRe: Volant cold air intake kit for 3.6 Who has one???
    I have the Volant set up and like the fact that it draws cold air from the grill instead of from under the hood. Also, it should provide some sort of ram air effect since the air is forced into the snorkel the faster you are traveling. I am sure I am braking some sort of rule with it but I am using either six #8 or #10 stainless screws to keep the rubber air filter element flange attached to the box. I did not like the slip fit because of possible air leakage as has been mentioned. Volant doesn't want you to screw it together so the filter can move around with the engine but I haven't had any trouble with screwing it together and I have made many full throttle blasts. Yeah, Michael is right, it was a biatch to get the snorkel positioned just behind the grill though and I only want to do that once.
  16. #14
    CTSCHICK Guest
    Thanks guys
    loosend your explanation is exactly what my b.f. said when I mentioned the few comments about the filter being loose in the box.
    He has stick on foam that can be wrapped around the portion that contacts the box or we also have clip on weather stripping if the plastic where the hole is on the box is thick enough for it to lock on good enough
  17. #15
    CTSCHICK Guest
    Thanks for the help guys I ordered it today for $255 shipped
    My b.f is going to do a mock up with it to see what you guys are talking about with the loose fitting filter in the housing..
    If you want to see how he corrects it just let me know and I will get a picture or 2
  18. Remove Advertisements
