Rx Catch Can "Gurgle"
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Like Tree1Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Rx Catch Can "Gurgle" in Cadillac CTS Second Generation Forum - 2008-2013; Anybody else hear their Catch Can "Gurgle"? Also, anyone install a catch can on the fresh air side (driver's side)?...
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Re: Rx Catch Can "Gurgle"
    If it is gurgling it may be full (any more than 1/3 full and the outlets from the coalescing chamber are in the contained trapped oil). Make sure to empty it when hot and engine off. The drain valve is open when in this position:
    And closed in this position:
    In the colder weather the can will also fill much faster due to the increased amount of water vapor in the crankcase and it will look a bit like chocolate milk.
    X E Ryder's Avatar
    X E Ryder is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Coupe, Premium, Touring
    Mar 2012
    Northern California
    48
    98
    I can never believe the "carnage" that appears in catch cans - Gross!
    May 2011
    Austin, TX
    37
    404
    Nope, nothing in it... I've never had anything drain out of it...
    X E Ryder's Avatar
    Mar 2012
    Northern California
    48
    98
    Quote Originally Posted by Michael_atDell View Post
    Have you taken a peek in the intake to see if there is any contamination / pooling oil? There should definitely be some buildup by each oil change.
    How often do you make hard wide open accelerations? (I'm curious for my own application) Thx
    May 2011
    Austin, TX
    37
    404
    Quote Originally Posted by X E Ryder
    Yes, there is oil in the intake; after installing the catch can, I assumed it was from the fresh air side that apparently dumps oil into the air intake.
    I make hard wide open accelerations very frequently... ;-)
    X E Ryder's Avatar
    Mar 2012
    Northern California
    48
    98
    Well dangit that oil is supposed to be in your catch can! What gives?
    Whose can is it if you don't mind me asking?
    May 2011
    Austin, TX
    37
    404
    RX Performance
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Something has to be hooked up wrong....can you post detailed pics of your install? Should be NO oil entering, and the can should catch the oil like all the others show.
    Oil will enter through the cleanside under WOT as well, but 95% plus is from the dirty side. Lets figure yours out Michael.
    To purchase the RX cans call direct: 941-721-1826 or go to: www.RevXtreme.com
    jimtreber is offline Cadillac Owners Member
    Jun 2005
    33
    With the sound system off, I've been hearing a gurgle for the last week or two. I first thought it might be low on coolant and air in the system. Checked it, OK. I was about to make an appointment with the dealership to check other hydraulics like the tranny or transfer case or power steering when I decided to drain the catch can. I had planned on draining it at each oil change but I only have 4200 miles on the oil (and 3 1/2 months). I live about 80 miles east of Chicago so we're in winter weather. The picture shows the amount drained. Gurgling stopped.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Yup! In the winter months drain it every 2k miles to see how much it is trapping. Every motor ingests different amounts so you have to first determine what your car is consuming.
    You do NOT want that in your intake air charge no matter what submariner thinks.
    jbelot's Avatar
    jbelot is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS
    Jul 2008
    Canada
    48
    I have had the same results. I’m super surprised at what comes out of the can. I am going to drain it in about 20 min, after I let it warm up, I'm half way to my next oil change. When it warms up outdide again I will take the intake off to look at the results as well as a cleaning to see it I can get the residual burnt oil off my valves that was caked on prior to catch can.
    jbelot's Avatar
    Jul 2008
    Canada
    48
    It has been about 5000km since I last changed my oil and drained the catch can. I drained about 1/4 cup of oil. This product seems to be doing it's job. Micheal, I think there is something wrong with your can. Maybe post pic of install or you may have a bad can.
  16. #14
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,136
    Quote Originally Posted by jimtreber View Post
    with the sound system off, i've been hearing a gurgle for the last week or two. I first thought it might be low on coolant and air in the system. Checked it, ok. I was about to make an appointment with the dealership to check other hydraulics like the tranny or transfer case or power steering when i decided to drain the catch can. I had planned on draining it at each oil change but i only have 4200 miles on the oil (and 3 1/2 months). I live about 80 miles east of chicago so we're in winter weather. The picture shows the amount drained. Gurgling stopped.
    wow!
  17. #15
    May 2011
    Austin, TX
    37
    404
    Anyone have the install instructions in PDF?
  18. Remove Advertisements
