Rx Catch Can "Gurgle" - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Like Tree1Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Rx Catch Can "Gurgle" in Cadillac CTS Second Generation Forum - 2008-2013; I only have a couple of links to threads in this forum on "HowTo" and a collection of info in ...
  1. #16
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,868
    Re: Rx Catch Can "Gurgle"
    I only have a couple of links to threads in this forum on "HowTo" and a collection of info in a "Word" document.
  2. #17
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,542
    Quote Originally Posted by jimtreber View Post
    With the sound system off, I've been hearing a gurgle for the last week or two. I first thought it might be low on coolant and air in the system. Checked it, OK. I was about to make an appointment with the dealership to check other hydraulics like the tranny or transfer case or power steering when I decided to drain the catch can. I had planned on draining it at each oil change but I only have 4200 miles on the oil (and 3 1/2 months). I live about 80 miles east of Chicago so we're in winter weather. The picture shows the amount drained. Gurgling stopped.
    What is that mess? Oil and water?
    Quote Originally Posted by Michael_atDell View Post
    Anyone have the install instructions in PDF?
    Have a look at my post when I installed mine. This may be good enough to get you there. First, check the hoses are on the correct ports of the can. http://www.cadillacforums.com/forums...tion-pics.html
  3. #18
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    Which hose goes to which valve? I remember installing via the instructions; I just want to verify.
  5. #19
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    The center of the can always attaches to the crankcase "dirty side". Generally a barb on one of the valve covers that goes stock to the intake manifold (NOT the intake air tube (CAI). Then the outer valve runs to the intake manifold for vacuum (where the stock line did run). Any on the cleanside, (the air box or intake tube) is not used except on a forced induction application.
    In the winter months, the cans will also trap a ton of water vapor as well so need to be emptied at shorter intervals than in the summer.
    To order, go to: www.RevXtreme.com or call direct: 941-721-1826
  6. #20
    May 2011
    Austin, TX
    37
    404
    That's how it's hooked up... I've opened it up to drain again since my first post, nothing comes out...
  7. #21
    May 2011
    Austin, TX
    37
    404
    Any suggestions?
  8. #22
    tinman's Avatar
    Jul 2006
    8,868
    If you have it hooked up correctly then what could it be? I can only think of something being wrong with the can itself.
  9. #23
    May 2011
    Austin, TX
    37
    404
    Maybe so, I never heard it before as it was attached to the engine cover stud. Over the Christmas break I moved it and attached it to a spot on the firewall... It's probably been making the noise all along, I just could hear it before. However, it's never had anything that's drained out if it at either location...
  10. #24
    May 2011
    Austin, TX
    37
    404
    SC2150, your inbox is full...
  11. #25
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    The can valve will always make a slight "buzz", but this is the drain closed...threads extended:
    This is the drain open, threads retracted:
    To check if the drain is open you can try and blow through the drain tube. If the drain is stuck you can remove it with a 9/16" wrench and it will drain and if thats the case let us know so we can send a replacement.
  12. #26
    May 2011
    Austin, TX
    37
    404
    Quote Originally Posted by SC2150
    That's it! I took the drain off and all kinds of crud starting running out! Yay!
    So, send me your email and I'll give you my address; I've moved since you shipped me this one.
    tinman and tinman like this.
  13. #27
    stagow is offline Cadillac Owners Member
    Automobile(s): 2009 CTS4 3.6
    Oct 2012
    23
    Yeah, I hope this is the answer to your issue. I just checked my can 3 weeks after installation and I wanted to make sure it was working. The valve really works hard (had to get a torque amplifier on it) but once open I got about a half to one cup of liquid out of it. Looked like mostly water as it was not real milky or overly oily. Good luck with getting it working well.
  14. Remove Advertisements
