Performance cams for our engine? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
2008-2013 Cadillac CTS Performance Mods Discussion, Performance cams for our engine? in Cadillac CTS Second Generation Forum - 2008-2013; Thanks, SC2150....
  1. #16
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    9,714
    Re: Performance cams for our engine?
    Thanks, SC2150.
  2. #17
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    4 cams are $1499 plus $15 S&H.
  3. #18
    Michael_atDell's Avatar
    Michael_atDell is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS 3.6L DI AWD
    May 2011
    Austin, TX
    37
    404
    Quote Originally Posted by SC2150
    4? I thought the 3.6 had dual cams?
  5. #19
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    2 per cylinder head. 4 cams total.
  6. #20
    bolt007's Avatar
    bolt007 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS DI Super charged
    Aug 2011
    Conyers GA
    41
    110
    Thanks I need to set a Appointment to get that done. I can lvm with Karen at 4pm today. Call me ASAP thanks!!!
  7. #21
    bronik90's Avatar
    bronik90 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe - 3.6l DI AWD
    Aug 2011
    Pittsburgh, Pennsylvania
    27
    101
    If anyone has experience with installing cams, I'd love to here from you. I'd like to get my hands on a set in the Spring and try the install myself. As long as I take my time, I'm fairly confident in my skills. I'm sure I can find videos/walkthroughs, but first hand experience is always a plus.
  8. #22
    mikesul is offline Cadillac Owners Enthusiast
    Automobile(s): 16 2.0T Perf, 8spd auto, dp, E85, tune
    Aug 2010
    S FL
    811
    Quote Originally Posted by SC2150 View Post
    $5600 (plus tax)
    Cams, Heads, New timing chains, Iceolator, CNC ported TB, all installed and tuned (includes gaskets, fluids, head bolts, etc.
    So pretty close to the cost of a supercharger installed?
  9. #23
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Very close.....and I would go with the SC if it was me personally, but this to go NA is pretty much the ultimate there (until the stroker crank is released).
    Dont do the timing chain, ported TB, etc. and this is in the high $4 grand range which brings it down a few grand below the super charger.
  10. #24
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    Whats the adverage rev limit after the cam kit like?
  11. #25
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    We still limit in the tune to 7k, but they pull through 8k where the stock ones start to fall off as far as peak power around 6700-6800.
  12. #26
    ztollon's Avatar
    Aug 2012
    629
    Have you gotten a motor to guinnie pig and see what you could redline at w no rev limiter? It would be interesting to see what numbers you could pull.
  13. #27
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Not yet, we stopped before 8k but the curve showed no sign of dropping yet.....with the stock valvetrain we dint want to push it further.
  14. #28
    ztollon's Avatar
    Aug 2012
    629
    Ohh boy
  15. #29
    leigh1322 is offline Cadillac Owners Member
    Automobile(s): 08 CTS 3.6 D.I. FE-3 6M Red
    Mar 2011
    61
    74
    Installing 4 cams in a DOHC motor is a long slow labor intensive process. You heard SC1250 mention 2-3 days. And they have done it before. Double or triple that if you are doing it for the first time. Mostly hand tools tho.. Front end and top end of motor comes apart. Tricky part is putting it back together and getting the timing chains installed with all 4 cams and the crank properly aligned, and on the compression stroke. Next slow part is doing a valve adjustment procedure on 24 valves, mostly likely with a feeler guage and replacing shims, and rotating the motor slowly. Last motor I did this way needed special tools to hold the valves open while removing shims and different size replacement shims. Haven't looked at the valve adjustment method on the 3.6 LLT yet, but on any DOHC there is hardly any other way of designing the valve adjustment. Then pop on the valve covers and intake and you are almost done!! :-) Easy right?
  16. #30
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    VERY diificult and leigh described it well. The 3 timing chains have to be installed and timined by slowly rotating in a several step process.....not for the light of heart.
    We see 30 RWHP gains soild with the cams alone.
    Heads compliment it all as well:
    And of course add the RX supercharger or turbo's:
    www.RevXtreme.com
  17. Remove Advertisements
