Another Catch Can Installation (with pics) - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Like Tree3Likes
2008-2013 Cadillac CTS Performance Mods Discussion, Another Catch Can Installation (with pics) in Cadillac CTS Second Generation Forum - 2008-2013; I'm quite familiar with Seafoam. But we have DirectInjection....
  1. #16
    tinman's Avatar
    tinman is online now Cadillac Owners Master
    Jul 2006
    Jacksonville, Florida
    8,852
    Re: Another Catch Can Installation (with pics)
  2. #17
    X E Ryder's Avatar
    X E Ryder is offline Cadillac Owners Member
    Automobile(s): 2012 CTS Coupe, Premium, Touring
    Mar 2012
    Northern California
    48
    98
    Quote Originally Posted by tinman View Post
    Refer to second half of post - you draw it in via vacuum port - works, just don't let it "drink" to fast.
  3. #18
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    Seafoam, BG, and every dealer service center will have similar...does work, but some of those hard particles are forced between the piston and cylinder walls causing minor scouring, so it should be used spareingly. It is one of the easiest ways to clean the vlaves some (only manual cleaning will clean them like new again).
  5. #19
    HurstGN is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS4 DI Black Raven/Ebony
    Jun 2012
    Pittsburgh, PA
    1,535
    Quote Originally Posted by X E Ryder View Post
    OK, what port? The pictures are not of a DI 3.6. If I pull the engine cover off, there is the vacuum line coming from the PCV/Catch Can side. With this port removed, the engine will not start. And if you try to do this with the engine already started, you can't keep it running once you remove this line. so where is the preferred location to introduce the seafoam? Not everyone has an assistant on-call to assist with these things.
  6. #20
    X E Ryder's Avatar
    Mar 2012
    Northern California
    48
    98
    Ok buddy I hear ya, but with no cable driven throttle body, you are going to need someones foot on the gas. Use the vacuum side going to the top, center front of your intake.
    I suggest using 3ft or so of clear 3/8" tube, and about 3ft of clear 1/8" tube - one that will slip INside the larger tube - overlap about 8" - this lets some air leak in around the two tubes and helps mix / regulate the flow of cleaner. Hold the small tube alongside the seafoam can and use a marker to indicate where about the top one third of the can is. Remember we use 1/3 the can only on a hot engine.
    Use a tube clamp or vise grips to pinch the hose off so you can start your CTS
    Carefully release the hose and meter the cleaner with the hose kink. You are being a sort of rudimentary carburetor! Your helper needs to increase rpm above idle as the engine labors on the cleaner some.
    Shut it off and wait 15 min - fire it up and clean it out good with some mellow revs, then go drive it hard a couple runs.
    I might try to make a video of this next week because I think this will come up again!
    (Whew messy post - using phone - ill fix later)
  7. #21
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    This is an article on Yahoo by Consumer Reports, see the link below to read it. Keep in mind one very important detail, in the article they reference a TSB sent to customers by Kia & BMW recommending a fuel additive once in a while. The problem with that is the fuel never touches the valves so additives are a complete waste of money with direct injection.
    Direct-injection engines improve performance and save fuel, but at a price
    It has been touted as the automotive holy grail, the ultimate marriage of better performance and greater fuel economy. It’s the direct-injection (DI) engine, the latest technology designed to squeeze more mpg out of cars. And it has actually been delivering results.
    For example, the Mazda3’s combined fuel economy jumped from 28 mpg in 2010 to 32 mpg in 2012 in our testing of the new Skyactiv engine. Other automakers have been using direct injection to add horsepower—the Cadillac CTS, for example, gained 34 hp—without any sacrifice in fuel economy.
    Though direct injection is currently seen mostly on luxury vehicles or on mainstream cars as a higher-trim option (priced anywhere from a few hundred dollars to a couple of thousand), it could soon be within the means of more drivers as costs continue to come down.
    But those engines are also having reliability problems, something that automakers are trying to keep quiet.
    Not surprisingly, a number of readers have asked us about direct injection. Take Anestis Halkidis of North Kingstown, R.I.:
    “I have a 2006 VW GLI with the 2.0T FSI engine with direct injection,” he wrote. “At around 80,000 miles, I went to the VW dealer to diagnose a check-engine light. It turns out that the intake valves had to be cleaned due to carbon deposits that were causing drivability issues.”
    When his dealer failed to offer free work or any compensation, Halkidis took his car to a local VW shop that cleaned the valves by blasting them with walnut shells. (Yes, walnut shells; it’s a method used by BMW.) The cost to Halkidis was about $400.
    So what’s up with direct injection?
    First, a primer on how it works: By injecting gas*oline at high pressure directly into the engine’s combustion chamber, direct injection more precisely measures fuel than conventional fuel-injection systems or old-time carburetors.
    The result is more complete combustion and cooler cylinder temperatures that enable a higher compression ratio for greater efficiency and power. Engine technology supplier Bosch says that direct injection can return a 15 percent gain in fuel economy while boosting low-end torque as much as 50 percent.
    Combining direct injection with other technologies—such as turbocharging—can deliver even greater gains in economy and performance. That in turn enables carmakers to use smaller displacement engines, resulting in an efficiency snowball effect. Many automakers are marketing DI as pro*viding fuel economy that’s almost as good as a hybrid’s, and with better performance—but without the $4,000 hybrid premium.
    Although the breakthrough seems like a dream come true, an unwanted side effect has been emerging. Letter writers have complained to Consumer Reports and the National Highway Traffic Safety Administration (NHTSA) that over time DI can lead to clogged fuel systems and engine carbon buildup. The result can be engine hesitation and a loss of power—and the need for expensive repairs.
    Some carmakers, including BMW and Kia, have issued technical service bulletins (TSBs) to their dealers recommending that drivers use only name-brand detergent gasoline—without ethanol additives—and that they periodically add a fuel-system cleaner when they refuel. (A TSB is an alert that the automaker sends to dealers to warn about ongoing problems with individual models and how to fix them. It may allow dealers to make repairs at little or no cost to the customer as a goodwill gesture.)
    Other automakers have devised an engineering fix that works while the car is oper*ating. It involves modifying the engine to spray a small amount of fuel directly onto the valves to help keep them clean.
    It’s important to note that not all cars with direct injection experience long-term problems. But if your engine stumbles more than it used to, or it suddenly lacks power, ask your dealer about it. A fix may be available, and you may not have to pay for it.
    This article also appeared in the February 2015 issue of Consumer Reports magazine.
    Consumer Reports has no relationship with any advertisers on this website. Copyright © 2006-2015 Consumers Union of U.S.
    https://autos.yahoo.com/news/direct-...amp;soc_trk=ma
  8. Remove Advertisements
