93 Premium Octane Gas Worth It?
Results 1 to 11 of 11
Like Tree2Likes
  • 4 Post By 00 ss
2008-2013 Cadillac CTS Performance Mods Discussion, 93 Premium Octane Gas Worth It? in Cadillac CTS Second Generation Forum - 2008-2013; The owner's manual says 87 Unleaded... Would a bone stock 2012 3.6 perform any better with 93 Premium Octane, or ...
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    The owner's manual says 87 Unleaded... Would a bone stock 2012 3.6 perform any better with 93 Premium Octane, or is it just a waste of money? Would the computer recognize the difference and adjust timing for better performance or is it locked down for 87 Octane?
    pote87 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS 4
    Jun 2012
    NJ
    29
    22
    Re: 93 Premium Octane Gas Worth It?
    I only use v-power in my 08 cts4, runs great on it plus i know the fuel injectors will be cleaner
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    9,081
    To answer your question, Austin, NO. I bet most people use the 87 like myself and there is no additional power. Just use a Top Tier gasoline such as Shell or Chevron or the others and 87 octane. You will experience no gains or losses in power. None. The only thing a higher octane is allow the compressed fuel to burn more smoothly and consistently under pressure which eliminate "knock". If your engine knocks then you have additional problems that the dealer should check into. The advanced computers we have in our cars will take care of the irregular detonation (should it even occur).
    Save your money.
    anhandrew is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Escalade ESV modded out, 2013 ATS LUX 2.5L
    Jul 2009
    Moore, OK
    144
    I can tell you running higher octane is definitely smoother.
    tinman's Avatar
    Jul 2006
    9,081
    There MAY be a slight improvement, but it is doubtful. Unless you are having problems save your wallet. Usually, the people who ask octane questions are the ones who want to downgrade from 93 to 89. Now they may have a slight problem, but it will still drive just fine. Maybe if you live at altitude you might consider a different octane or drive your car hard or track it.
    00 ss is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4
    Feb 2012
    Colorado
    457
    I live at altitude. We use LOWER octane fuel up here. Regular is 85, mid grade is 87 and premium is 91. I use 91 in my '00 Camaro SS because I get knock retard with lower octane which reduces power. The CTS gets regular and has no knock retard. Unless you have a good scanner, you will not know if you have knock retard or not. It's not displayed anywhere.
    Like others have said, the 3.6 is designed for regular gas. Putting premium in will (at best) do nothing and could reduce power because the fuel burns more slowly. To maximize performance, never use more octane than you need to prevent knocking and pinging. Oddly enough, this also minimizes fuel costs. This may be the only exception to the rule that performance costs more.
    tinman, tinman, Getch78 and 1 others like this.
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    As others said - NO. Use regular gas and you will be fine. Unless of course you want to waste money for placebo effect
    spind is offline Awaiting Email Confirmation
    Automobile(s): 2015 ATS 2.0T AWD Performance
    Jun 2011
    Ontario, Canada
    182
    Some higher octane fuels contain no ethanol, as ethanol contains less 'power' than gasoline an increase in fuel economy and responsiveness may be noticed
    tinman's Avatar
    Jul 2006
    9,081
    Still, no noteworthy advantage to any of us. Our cars were built for low 87 octane ethanol blend gasoline.
    Jun 2011
    Ontario, Canada
    182
    http://en.wikipedia.org/wiki/Ethanol_fuel
    "For E10 (10% ethanol and 90% gasoline), the effect is small (~3%) when compared to conventional gasoline,[56] and even smaller (1-2%) when compared to oxygenated and reformulated blends.[57] For E85 (85% ethanol), the effect becomes significant. E85 will produce lower mileage than gasoline, and will require more frequent refueling. Actual performance may vary depending on the vehicle."
    Hammerhead100's Avatar
    Hammerhead100 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS Performance Sedan
    Sep 2012
    South Carolina
    160
    Quote from the Federal Trade Commission:
    The Low-Down on High Octane Gasoline
    Are you tempted to buy a high octane gasoline for your car because you want to improve its performance? If so, take note: the recommended gasoline for most cars is regular octane. In fact, in most cases, using a higher octane gasoline than your owner's manual recommends offers absolutely no benefit. It won't make your car perform better, go faster, get better mileage or run cleaner. Your best bet: listen to your owner's manual.
    The only time you might need to switch to a higher octane level is if your car engine knocks when you use the recommended fuel. This happens to a small percentage of cars.
    Unless your engine is knocking, buying higher octane gasoline is a waste of money, too. Premium gas costs 15 to 20 cents per gallon more than regular. That can add up to $100 or more a year in extra costs. Studies indicate that altogether, drivers may be spending hundreds of millions of dollars each year for higher octane gas than they need.
  14. Remove Advertisements
